04-02-2015, 09:07 PM | #1 |
1301
Rep 2,093
Drives: '11 135i M Sport
SOS Error w/ Heater On
Monday while driving to work I noticed i was running at 250 temp so I decided to put the heat on half way and crack the windows to bring the temp back down some. After about 20 minutes the SOS/Bluetooth disabled came on. I did some searching about it when I got to work and just seemed to be a glitch. So I ignored it.
Today I was driving home and noticed it was at 250 temp again so I did the same procedure to bring the temp back down. 20 mins later I get the same SOS/Bluetooth error. I turned the heater fan off. After half hour the error goes away and I get static for a second through the stereo and then all is well. Whats up with this? Is it possible that the heat coming through the dash is getting a component too hot? Also I can still use the radio. Select channels and still gets signal, just no sound. |
04-04-2015, 07:50 PM | #2 |
1301
Rep 2,093
Bump
04-04-2015, 09:54 PM | #3 |
43
Rep 205
Are you turning the heat on when the oil gauge is at 250? Or do you have a separate coolant gauge that's running at 250? The gauge on the dash is for oil not coolant, and I could be wrong but I don't think turning the heat on will cool down the oil.
04-04-2015, 09:56 PM | #4 | |
1301
Rep 2,093
04-06-2015, 04:33 PM | #5 |
827
Rep 3,856
04-06-2015, 09:55 PM | #6 | ||
283
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
As far as your issue, that's really odd. I would look through Real OEM to try and find the location of your Bluetooth module, it may shed some light on the issue
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
04-07-2015, 05:10 PM | #7 | |||
1301
Rep 2,093
04-07-2015, 06:50 PM | #8 | ||||
283
Rep 888
04-07-2015, 07:02 PM | #9 | |||||
1301
Rep 2,093
04-07-2015, 07:34 PM | #10 |
209
Rep 893
06-28-2015, 05:01 PM | #11 |
Rep 53
Sos Sign On Dash Board With Bluetooth Function
gee! well I also noticed that mine fairly used bought 2009 128i BMW non iDRIVE convertible shows the SOS sign, with consequent loss of the Bluetooth function and audible which was working before. The radio works and CD works. Can this failure effect the performance of the Engine. This condition has been on for days now, even with offing and restarting the Engine.
