      04-01-2015, 04:11 PM   #1
KNS
137
Drives: 128i and Porsche
Oil temp gauge is 128i
New guy here with a question - I didn't see it in a search unless my search skills need help...
Can the oil temp gauge cluster (actually the whole instrument cluster) from a 135i be swapped into a 128? I would assume the sensor is there, just wondering if anyone has looked into it or done it. I imagine some ECU fiddling would be necessary.
Thanks
      04-02-2015, 03:09 PM   #2
JimD
JimD's Avatar
368
Drives: 128i convertible
If the sensor is there, you could create a virtual gauge in Torque or a similar program. I don't remember seeing it but my memory isn't perfect. There is also a device that puts a gauge in place of part of one of your vents on the dash. Either an app for your phone or an additional gauge would be a lot cheaper than swapping the instrument cluster.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      04-02-2015, 06:35 PM   #3
KNS
137
Thanks for the reply...!
      04-02-2015, 07:14 PM   #4
mr.fabulous
mr.fabulous's Avatar
209
Drives: Women Crazy
I was hoping to be able to tell you an OBD-II gauge (like UltraGauge) would work... but they don't list Oil Temp as being available on their site:
http://www.ultra-gauge.com/ultragauge/TEN/gauges.htm
... and then I found this:
http://www.1addicts.com/forums/showthread.php?t=540223
So ultimately I am of no help. * sigh * My ex-wife would agree :O/
      04-02-2015, 08:27 PM   #5
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
998
Drives: 2012 E82 6MT Sport
Yeah, I wish it would display oil temp, but at least it displays coolant temp which is better than what the instrument cluster displays, which is nothing.
      04-02-2015, 08:37 PM   #6
631twentyeighteye
631twentyeighteye's Avatar
198
Drives: 08 335i
The 135i dash will work, it might require some coding but it will work.
08 e93 335i MT
      04-02-2015, 11:32 PM   #7
KNS
137
Do you know this for a fact? I ask because I talked to a service guy at a dealer (after I started this post) and he said the oil temp sensor in the 128 wasn't there for use. He might be wrong of course...
Thanks
      09-16-2015, 12:32 PM   #8
chris82
chris82's Avatar
827
Drives: 128i
2009 BMW 128i  [9.80]
Thanks
any updates op?
I may need to do an instrument cluster replacement at some point, would like to get that oil temp guage the 135i has. I just need to know if the sensor is there on our cars
      09-16-2015, 01:41 PM   #9
Bimmer-Bob
Bimmer-Bob's Avatar
698
Drives: 2010 128i
Originally Posted by chris82 View Post
any updates op?
I think Stig has an electronic Performance steering wheel on his 128i - maybe ask him if he can pull up engine temp on it?
      09-16-2015, 02:45 PM   #10
KNS
137
As much as I would like to have an oil temp gauge, I went ahead and got the P3 cars vent display. It does not display oil temp but water/coolant temp instead (which is still useful information). Someone told me the 128i does not get a reading (that can be used for display purposes) for oil temp but I don't think that is true.
Having the display for the coolant temp now it is interesting to see how the water pump and thermostat behave. Coolant temp is constantly fluctuating - up, down or staying constant. Not like a traditional WP and T stat at all but completely normal for these cars. It is really based on the demand of the engine under varying conditions.
Chris, If you do swap in a 135 cluster and it works let us know!
      09-17-2015, 06:52 AM   #11
JimD
JimD's Avatar
368
The reason you can't get the oil temperature on the 128i is there is no sensor. I don't know where the sensor is on the 135i but you might get an idea from RealOEM. The wiring harness may already contain the wiring to hook it up. If you are lucky, it would just be a matter of screwing in the sensor. But it could also be that the car would not recognize the sensor even if it is hooked into the harness. It depends on the programming.
      09-17-2015, 07:44 AM   #12
chris82
chris82's Avatar
827
Drives: 128i
Thanks all, TheSt|G how did you get your oil temp or coolant temp reading to work with your BMWP V2 steering wheel?
      09-17-2015, 08:37 AM   #13
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
298
Drives: 911, 130is, E39 M5, E36 M3
Wrong.
Wrong.
Hugely wrong.
I have the V1 wheel, but I doubt the situation is any different for the V2 wheel. The car already has the sensors in place for oil temp to the degree, coolant temp to the degree, accelerometers for G-Force detection, and a whole other host of things. The V1/2 electronic wheels simply tap into the harness and display that information:
(screen looks dim/spotty because like most screens, the refresh rate goes crazy with cameras)
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
Appreciate 3
      09-17-2015, 01:40 PM   #14
chris82
chris82's Avatar
827
Drives: 128i
Originally Posted by TheSt|G View Post
Wrong.
Wrong.
Hugely wrong.
Thank you! Sorry didn't know if you had the V1 or V2 wheel.
Okay, this is very good news
      09-17-2015, 02:28 PM   #15
The Wind Breezes
912
Drives: 135i N55 DCT
You guys are silly. Of course the 128i has an oil temp sensor. All cars have them nowadays. It's a hugely important piece of monitoring equipment.
Seeing the temp is just a matter of hacking up a gauge and getting it to read the value on way or another.
      09-17-2015, 09:26 PM   #16
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
135i cluster.
      09-17-2015, 10:45 PM   #17
vtl
vtl's Avatar
Australia
1493
Drives: 2008 BMW 135i MT
Buy a used 135i cluster.
You need to disassemble the cluster, remove the dials and gauges, desolder the eeprom and write your VIN number to it. You will need a new M35080 eeprom if the milage from your donor cluster is higher than your vehicle milage. The M35080 chip only accept odometer writes that are greater than the existing odometer reading to stop people from turning back the clock. New chips are on ebay for $3.
You will then need to re calibrate the dial needles, then code the cluster.
I have done this twice for people who wanted to fit an M3 cluster into a 335i
      09-18-2015, 06:14 AM   #18
Taskmaster
Japan
2465
You can install a 135i cluster and just have someone code it for you, sometimes they work without coding.
      09-18-2015, 07:15 AM   #19
vtl
vtl's Avatar
Australia
1493
Not coding is a hack install imo. Cant code unless the vin matches. Will get tamper dot if theres a mismatch
      09-18-2015, 07:19 AM   #20
Taskmaster
Japan
2465
Never heard that before.
      09-18-2015, 07:36 AM   #21
vtl
vtl's Avatar
Australia
1493
Just search for "tamper dot" and there's plenty of posts. Ncs expert throws a hissy fit and won't allow you to code the cluster when there's a vin mismatch trust me
      09-18-2015, 07:56 AM   #22
KNS
137
All good info! Just for the record, I didn't say there wasn't any oil temp sensor - I was told that by a service guy at a dealer (which I found hard to believe).
1addicts
