03-30-2015, 10:02 AM | #1 |
225
Rep 770
Brushed Aluminum Trim Care?
Any trick to keeping the aluminum trim clean and protected. I've seen some older Z4's with aluminum and it looks pretty dirty and worn out.
03-30-2015, 11:16 AM | #3 |
Mechanical Engineer
96
Rep 1,025
1. Stare at aluminum trim, wishing it was not aluminum.
2. Wipe down with interior detailer. Clean, but still f**king aluminum. 3. Repeat. .... 100. Buy leather or wood trim. |
03-30-2015, 11:38 AM | #4 |
#buildnotbought
10890
Rep 4,898
100. fake wood trim.....
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
03-30-2015, 11:50 AM | #5 |
851
Rep 4,057
Also, warm water and a clean microfibre cloth, brushing lightly in the direction of the grain on the trim.
Its been a source of great angst among Z4 owners who were not the initial buyers of these cars. Seems the first owners kept the cars in good shape - except for the aluminum trim, which they apparently took great joy in beating the snot out of with keys, coins and the seatbelt buckle.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
03-30-2015, 12:10 PM | #7 |
Mechanical Engineer
96
Rep 1,025
03-30-2015, 01:15 PM | #9 |
My other car is on Mars
636
Rep 3,124
I've always preferred woody things over tinny things.
Warning: May contain traces of nuts.
03-30-2015, 01:53 PM | #10 |
salty cowboys fan
6168
Rep 3,411
Probably not the best solution, but I usually end up using 303 aerospace protectant, because that's what I use on nearly everything else interior-wise. I spray a clean rag with it and wipe everything down. Just did it yesterday after a wash; metal is very clean with a smooth, non-greasy finish. I bet just using a damp rag (water only) would probably have the same effect.
03-31-2015, 01:52 AM | #11 |
45
Rep 384
You'll be amazed!
Clean heavy dirt like smudges around the radio and sport button with a Pink Pearl eraser just like the one your kids use in school. Just erase the smudges like you were taking an algebra exam and vacuum up the rubber crumbs, your aluminum trim will look BRAND NEW! My brushed dash is 9 years old and as bright as day one. If all your trim is dirty, buy more erasers. I just thought I'd try it one day after trying every wet cleaner in the cleaning aisle. Now I keep one in the glove box to spot clean as i notice the dirt.
The Internet said it. I believe it. That settles it!
03-31-2015, 03:14 AM | #12 |
504
Rep 878
Not that I have the aluminium panels in my car but my fridge is brushed aluminium and it was a pain to keep free from smudges, until I started using window cleaner (which contains alcohol). Leaves zero stains. I wipe it with a microfibre cloth used for windows.
04-01-2015, 11:20 AM | #17 |
17526
Rep 10,675
Drives: M4 CS. Former G82, x2 F82, F80
Sure, check out this thread. My pics start in post #9. I'm going to wrap the interior more once my car gets a bit more wild on the outside. I'm definitely going to do the interior pillars.
http://www.zpost.com/forums/showthre...ighlight=vinyl |
04-01-2015, 11:25 AM | #18 | |
27
Rep 223
04-01-2015, 11:27 AM | #19 | |
140
Rep 1,991
04-01-2015, 11:43 AM | #20 | |
17526
Rep 10,675
04-01-2015, 01:57 PM | #22 |
17526
Rep 10,675
Thanks. What is "Felted Napa" though, is that the carbon leather?
With the new wrap, a lot of my interior is looking a bit faded. I bought a new shiftknob when I bought the car, but I want to go with the small M5 one. As well, once I get my calipers installed, I'm looking into doing a lot of the cabin stitching in the same color. I want to get a new shift boot, ebrake, ebrake boot, and steering wheel redone (along with the buttons on the wheel). Once I do all of that, the interior should look a lot better. |
