03-26-2015, 07:25 PM | #1 |
74
Rep 412
Need quick help on bleeding the clutch after CDV delete??
Wut to do? I think I see the nipple but do I just completely take it off? What's the procedure to bleed it? the DIY stickied doesn't really say much on the clutch bleeding... http://www.1addicts.com/forums/showthread.php?t=209440 |
03-26-2015, 08:15 PM | #2 |
The Crowing
111
Rep 2,005
It says in step #6 in the link you posted. You loosen the bleeder a little and have someone press the pedal to the floor and keep the pedal there. There should be fluid come out of the bleeder valve. Once the pedal is to the floor you tighten the valve back and then let the pedal back up. If you don't close the valve before you lift up on the pedal it may suck air in through the bleeder valve. You might see some air bubbles come out of the valve as well as fluid when the clutch is pressed in. Same concept as when bleading the brakes.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback Last edited by MuNkY6913; 03-26-2015 at 08:20 PM.. |
03-26-2015, 08:42 PM | #4 |
The Crowing
111
Rep 2,005
Did air come out of the bleeder valve? Make sure you have enough fluid up top.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
03-26-2015, 08:47 PM | #5 |
European Editor
10589
Rep 22,992
I used a pressure bleeder when I installed my CDV delete. I only opened the clutch slave's bleeder a few turns. Just enough for fluid to come out. Then after say 8oz's I closed the valve - checked my pressure bleeder for fluid and repeated. I never touched the brake pedal until I was finished.
When I did use the clutch pedal... it went(and stayed) on the floor. I pulled the pedal up with my hand and pumped the clutch pedal. Then I re-bled the entire system AGAIN. Make sure you get that CDV clip back on fully. Its easy for it not to fully snap back on(and leak). Good Luck, Dackel
03-26-2015, 08:58 PM | #7 | |
74
Rep 412
03-26-2015, 09:02 PM | #8 | |
European Editor
10589
Rep 22,992
You could also try reverse bleeding the clutch slave. Go out to your local hardware store and buy a NEW oil(er) can.
03-26-2015, 09:14 PM | #9 | |
74
Rep 412
03-26-2015, 10:02 PM | #11 |
340
Rep 1,293
I used a pressure bleeder and was getting pure fluid to come out the bleed valve. When I shut the bleed screw, I still had to pump the clutch 50-100 times before the clutch pressure felt normal. Give that a try before opening up the system again. Trust me, it took forever but the pedal pressure returned to normal.
03-26-2015, 10:04 PM | #12 | |
74
Rep 412
03-26-2015, 10:20 PM | #13 |
1Addict
3233
Rep 7,894
Screw it close (tight), get in and pump the clutch until it feels good again.
03-26-2015, 10:44 PM | #14 |
74
Rep 412
I've been at this for four hours. Shits still the same. Going to call the tow truck tomorrow :bs:
2015 m235i 6mt
03-26-2015, 11:00 PM | #15 |
The Crowing
111
Rep 2,005
Try turning the car on and pump the pedal 15-20 times. Turn it off. Then bleed again and see if air comes out. Don't pump it with the bleeder open. Only one press on the pedal then close the bleeder. Starting it may give a little vibration if there's some stubborn bubbles.
03-27-2015, 03:42 AM | #16 | |
European Editor
10589
Rep 22,992
Don't look a the front of the reservoir... but the back part of it! The reservoir has a divider in the rear just to make sure the clutch circuit won't drain the brake reservoir of brake fluid. I bet the rear is dry/empty.
03-27-2015, 10:32 PM | #18 |
The Crowing
111
Rep 2,005
What ended up fixing it?
03-27-2015, 11:21 PM | #20 |
The Crowing
111
Rep 2,005
Hahaha. So more fluid? Couple more bleed cycles? Just asking cause I'm going to be doing this as well soon and I like to know answers to the problems other people had.
03-27-2015, 11:57 PM | #21 | |
74
Rep 412
At least I think that's how it went. Lol. I'm just glad things turned out the way they did. |
03-28-2015, 12:36 AM | #22 |
The Crowing
111
Rep 2,005
Ahh. Ok. He used a pressure bleeder. Thanks for the update!
