03-23-2015, 09:38 PM | #1 |
90
Rep 341
What is more damaging: Throttle or RPMs?
What essentially causes more wear and tear on a vehicle, wide open throttle, or high revving RPMs? Or are they pretty equal?
I drive a 6AT N54 135i, and I always drive using automanual mode, and I'm actually pretty anal about what RPM I shift at. I never rev above 2.5k before the temp needle gets above 160F, and even afterward, I normally don't go above 3-4k even when doing pulls. It's stupid, but I love my car and don't want to beat it up I'm curious what will cause more wear and tear on the car, high amounts of throttle, or high RPMs. Say for instance somebody uses WOT but still shifts at 4-5k instead of letting it get to redline RPM @7k. Are they still causing a similar level of wear and tear to the vehicle, or is there practical merit to shifting early to save on some engine wear?
Model: '08 135i N54 6AT Coupe ///M Sport - E85 + 93 = E30
Mods: AA DPs + Gen I - BMS JB4 (Race + Map 2) + DCI + OCC - Cobb CP - ///M RSFB + Front Control Arms - Koni Yellow - Swift Spec R - Vorshlag camber plates - MPSS 225/255 - x-ph Angel Eyes 160w |
03-23-2015, 10:44 PM | #2 |
340
Rep 1,293
I prefer to drive as slow as possible all the way to redline. In all seriousness, WOT tends to be harder on your drivetrain, while revving to redline is hard on reciprocating parts like the pistons, connecting rods, valve train, etc. The speed at which the piston changes direction at redline (without shooting through the hood) is an amazing feat of engineering. Thankfully modern ECUs do their best to keep you from doing too much damage.
03-23-2015, 10:49 PM | #3 | |
2015 X1 35i XDrive with NAV
76
Rep 659
Drives: 2015 X1 35i
First your N54 is forged so it can take allot of abuse, more then you will give it in your daily driving. Second, WOT depending on your tune can wash the piston walls and or build up deposits. Not something that happens much but, it can under extreme conditions. Just drive it and don't worry about abusing it. BMW engineered this car for performance and way more abuse then that. If your going to baby it there was no point installing the JB4 (map 5).
So just go and enjoy it. Quote:
2015 X1 35i XDrive Ultimate, NAV & Cold Weather Package MHD, FTP Motorsports Charge Pipe, Drop in K&N |
03-24-2015, 11:03 AM | #4 |
1Addict
3233
Rep 7,894
No point in running it up past about 6300 rpm. Otherwise enjoy the car and drive it! It begs for punishment. Masochistic little things they are.
03-24-2015, 11:37 AM | #5 |
189
Rep 1,026
03-24-2015, 12:00 PM | #7 |
2285
Rep 12,565
Drives: Z4 M, X5, GX460
x10
03-24-2015, 12:27 PM | #8 |
oooooo
53
Rep 320
Bottom line (in my humble opinion) is these motors are pretty tough and outside of very high tunes | boost, and failure to provide adequate fuel | oil circulation they will take a lot of abuse as a street car. Real track time and racing is an entirely different animal.
I also think its a mistake (from a maintenance and enjoyment perspective) to baby these engines. If oil temp is up shift in 4-5k rpm range at least a few times during every drive cycle. Occasionally I like to keep it between 4-5k for every gear if Im running the mountains! When the engine is cold obviously you dont want to rev it high but equally as important is to avoid "heavy loads" being placed on the engine or turbo when cold. What I mean by this is lugging in 4th gear with the pedal all the way down so you can get up a hill is actually asking the cold engine and turbo to do more than slowly reving to 3,500 rpm in a lower gear. Think about what you are asking the car to do with your throttle input and how the gear you are in relates to work load for the engine. Once she warmed up.....LET IT EAT!!!!!!
2011 135i - Gone but not forgotten | 2017 M2 - Powering out of a corner near you!
03-24-2015, 12:27 PM | #9 |
561
Rep 755
03-24-2015, 12:47 PM | #11 | |
139
Rep 575
At what temperature would you say that the engine has warmed up already? Oil temp needle moving above 160F? Or when it reaches steady state temperature at approx 240F? Thanks.
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
03-24-2015, 12:54 PM | #13 |
189
Rep 1,026
03-24-2015, 01:20 PM | #14 | |
139
Rep 575
I've done high RPM runs when the oil temp was at 180F or so.. Hope that's OK.
03-24-2015, 04:30 PM | #15 |
1Addict
3233
Rep 7,894
It's probably fine every once in a while. Who knows over the long run though.
03-24-2015, 04:31 PM | #16 |
1688
Rep 3,140
Drives: 2014 M5 6MT
I wait till my JB4 tells me the engine is warmed up before I go over 3k rpms. After that, it's the beans. I don't drive my car easy.
2014 M5 6MT
03-24-2015, 04:49 PM | #17 |
209
Rep 893
03-24-2015, 04:50 PM | #18 |
1688
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
03-24-2015, 08:13 PM | #19 |
Rep 16
I think your over thinking this a bit. Obviously you don't want to redline it but you certainly don't want to be lugging it when it's not warm yet either. Try to avoid boost, if it has to spool some to get up a hill or something let it happen. Personally I think keeping the revs too low to keep the cold engine out of boost is worse than putting your revs where they need to keep the engine under little load.
I always think of it like a mountain bike, your trying to make your car climb a hill in 14th gear, your gonna pull a leg muscle. As for warmed up, let her have it once in a while and burn off some of that carbon build up. I usually row through a few gears multiple times a day. For what it's worth, my Subaru didn't have forged internals like your BMW, had 340 all wheel hp which puts much more of a shock on the motor and drive train and I beat the balls off of it for 40,000 miles. I'm talking flat foot shifts, 4.5k rpm launches, flat spins, you name it. It had 80k on it when I bought it too. I had a tune done again right before I sold it and it was still holding good boost and barely used oil. Last edited by Elemento1991; 03-24-2015 at 08:22 PM.. |
03-24-2015, 08:55 PM | #20 |
1130
Rep 4,686
Drives: L'Orange
don't overthink it.
just maintain it well, drive it, and enjoy it... |
03-24-2015, 10:57 PM | #21 |
283
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
A while back I read something a Z4 owner wrote about lifter tick. He found that while babying the car he experienced lifter tick on his N52. If he shifted only above 4000RPM once the engine was warm, the to I disappeared
He concluded that the engine was designed to be driven over 4000 RPM, and babying it was actually harming the engine. Food for thought
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
