03-20-2015, 05:22 PM | #1 |
26
Rep 325
First gear
Hey guys
I've installed a Bmw SSK and modified the CDV (zeckenhausen) But letting go of the clutch slowly into first gear, while slowly accelerating at the same time does NOT equal a smooth shift. Shift is jerky and annoying.. I hate first gear so much that I do everything I can to transition into second... Should I try a different transmission fluid? Only 20k miles!!
Mods: Clutch stop, BMW performance SSK, BMW PE exhaust, CDV delete, Clutch pedal spring delete (CPS delete) : ) - check out the the DIY:http://www.1addicts.com/forums/showthread.php?t=1122797
03-20-2015, 05:27 PM | #2 |
968
Rep 3,323
I have the BMW SSK and have not experienced this. But, being in 1st gear for such a short time maybe I haven't noticed it. I don't have the CDV delete. My SSK was a direct replacement for the stock shifter. No issues I'm aware of.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
03-20-2015, 05:56 PM | #3 |
26
Rep 325
I don't mean moving the shifter
I mean the clutch feels jerky in first gear
03-20-2015, 06:14 PM | #4 |
European Editor
10589
Rep 22,992
Sounds like you STILL have a CDV. I would either bypass the cdv or take a 3mm punch or small flat blade screw driver and knock out the restrictor inside the CDV. I bet you still have a restrictor inside the CDV.
See my post, #190... http://www.1addicts.com/forums/showt...=209440&page=9
03-20-2015, 07:02 PM | #5 |
340
Rep 1,293
Does it feel like the car is being tugged by a large bungee cord? I get the same feeling occasionally when the car is cold and I have removed the CDV. Mine seems to smooth out after a couple minutes of driving. I've always assumed it was the DMFW. Unlike the CDV, it goes away when the car is warm. My buddy's E92 M3 does the same thing, again when cold, but it's so bad it makes your head snap back and forth like that SNL skit Night at the Roxbury.
03-20-2015, 07:34 PM | #6 | |
26
Rep 325
03-20-2015, 08:04 PM | #7 |
26
Rep 325
Dack
Is it possible not bleeding the clutch 100% can result in jerkiness?
