      03-20-2015, 02:11 AM   #1
Killswitch
Killswitch's Avatar
33
Drives: A Car
1991 BMW 318is  [0.00]
2008 BMW 128i  [0.00]
Polishing Pad/Buffing Pads: How are you guys cleaning them?
I have a quite of few correcting pad for my orbital that are used and to be honest to not sure how to properly clean them and store. Wanted to know a good way to remove polishes from the pads and how long should they last before tossing it?
      04-02-2015, 01:24 PM   #2
dball4
dball4's Avatar
17
Drives: '09 M3
If the pads are foam or microfiber, I would recommend DP Pad Rejuvenator and a good soaking in warm water. If you don't have access to that, soaking the pads in water for 20-30min, and then using dish soap and a nylon brush to remove any polish or wax residue left in the pads. Rise thoroughly, and dry with the velcro/backing plate side up, to prevent deterioration of adhesives that mate the pad and contact patch. To answer your question on pad life, it is really up to your discretion, but if the pad is deteriorating and the microfiber/foam begins to fall apart under use, time to replace them. Hope this helps.
'09 E90 M3, DCT Silverstone
'71 GTV
      04-02-2015, 04:16 PM   #3
originalgoods13
290
Drives: Chevy Spark
For more porous foam pad like the yellow conditioning foam pad, sometimes it is tough to get rid of the wax or sealant residue even after washing.
You can replace or just wash them a couple of times on a natural dish detergent or your preferred foam pad cleanser (works better)
      04-09-2015, 10:13 AM   #4
pj.rodriguez
pj.rodriguez's Avatar
84
Drives: Alpine White 128i Cabrio
I definitely recommend a foam pad cleaner. It is a solvent that will just eat away the sealant or waxes or compounds that are stuck in the foam pad. After that, use warm water and a brush to get the cleaner and all of the residuals out of the pad. Rinse super thoroughly and place face down to dry. This allows the water and any other residuals to come to the face of the pad and not be stuck deep down in the pad where it would be more difficult to see and you'll wonder why the pad doesn't work that well anymore. Face down is the best tip I can give when drying the pads.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
      04-10-2015, 02:11 PM   #5
Zombie1
172
Drives: BMW 135i 2010
Wink Chemical Guys makes great products
http://www.chemicalguys.com/Microfib..._p/cws_201.htm
http://www.chemicalguys.com/Foam_Woo...buf_333_16.htm
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
      04-10-2015, 08:35 PM   #6
moosey
Drives: 128i
I've had good luck w/ Dawn Power Dissolver
      04-14-2015, 01:29 PM   #7
bNks334
bNks334's Avatar
427
Drives: '11 135i (N55)
What pads are you guys using in general? I used some cheap ones from harbor freight on my DA and they are pretty much a 1 time use thing. They start to deteriorate instantly. Cant see reusing a pad anyway as dirt, compound, and wax tend to be pretty hard to clean off.
      04-15-2015, 08:53 AM   #8
Zombie1
172
Talking yikes
Please don't use those pads on your car sir. It's worth it to invest in a nice set of pads they'll last a LONG LONG time. The fist set of pads are used by a lot of car care pros. The second and third links show Microfiber polishing/cutting pads that are newer to the market. I have used them and I love them for my BMW jet black paint(known to be a very soft clear). hope this helps
http://www.chemicalguys.com/Hex_Logi..._hexkits_8.htm
http://www.chemicalguys.com/Black_Op...bufx_305_6.htm
http://www.chemicalguys.com/Black_Op...bufx_304_6.htm
      04-16-2015, 11:14 PM   #9
cmac49
cmac49's Avatar
Drives: 2014 BMW M5 Competition
Thanks for the links. I just bought a '12 black 135i and am determined to maintain the current state of the clear coat as it looks fantastic ATM.
      04-17-2015, 07:32 AM   #10
bNks334
bNks334's Avatar
427
I need hook and loop type pads... any suggestions on those?
      04-17-2015, 08:56 AM   #11
Zombie1
172
Wink
Yes they have those style pads on chemical guys in their hex logic pads and lake country.
      04-21-2015, 09:46 AM   #12
Killswitch
Killswitch's Avatar
33
Drives: A Car
Thanks for the helpful hints and suggestions guys. Definitely will utilize those tips. I have used pads stacked and its time to clean and reuse. I have an old e30 thats begging to be polish.
1addicts
