03-18-2015, 05:41 PM | #1 |
46
Rep 406
Fixing Headlight...
03-26-2015, 01:43 PM | #2 |
39
Rep 323
Wetsand @ 1000G and then maybe 1500/2000 Grit until a real even cloud appears. Then, have it clear coated. Either have a shop do it or just get some good quality aerosol. Do multiple, light coats. You should be good and the fix is pretty much permanent. If the clear coat is a little wavy and bumpy, you can then wetsand that w/ 2000 grit and polish after.
03-26-2015, 07:41 PM | #3 | |
130
Rep 351
Take a look at the link below and check out my instructions as well as the videos. http://www.1addicts.com/forums/showthread.php?t=1105457
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
