      03-17-2015, 01:38 PM   #1
feeshta
58
Drives: 2012 135i 6MT, Alpine White
How does everyone mount their phone in their 1er?
Hello all. Picked up my new(to me) 135i this past saturday, and in my travels I noticed a minor complication. I use my phone for GPS purposes when needed, and often use Waze to help look out for cops on long trips, even when I know exactly where I am going. This means I need to have the phone plugged in, or it kills the battery pretty quickly. In my old 540i, I simply used a suction cup windshield mount with a magnetic mount for the phone to hold my phone and then plugged the lightning cable into a 2 port USB charger in the stock 12V location. I usually mounted my phone on the left side of the steering wheel next to the A-pillar, as that keeps it out of the way and within arm's reach. Center mounting puts it too far away to reach.
Now, in the 135i, the armrest area location of the charge port makes that impossible, at least without a 6 foot cord or something like that, and I really don't feel like snaking a cord all over the interior. As these cars apparently only do Bluetooth for the purposes of phone calls rather than streaming, it is also important to be able to plug the phone into the factory USB for steering wheel track selection and the like.
So what solutions have you guys seen or come up with for your cars? I know I can't be the only one who wants to have a better solution. Is there some way to get a mount to work down in the center console area? Am I missing something with Bluetooth options? I've tried searching both on google and here on the board for E82 phone mount options, and I'm not coming up with much. the only thing I have seen so far is the one that clips over the vent opening, and I don't really care for that option.
So, any ideas guys?
      03-17-2015, 02:03 PM   #2
methodz
40
Drives: '12 Le Mans 135i Vert
I don't know how you want to mount it. I haven't found a good place for my phone yet. I did buy this and am figuring out how to mount tablet on in front of my gps display because I never use it:
My car does both calls and streaming so if yours does not you should look into this:
I had it and it was awesome. Auto paired when I entered the car and pauses music on a call and pauses when the car needs to alert you of something like if you have your phone connected to the car and you only use the kinivo for music.
      03-17-2015, 02:16 PM   #3
mahlerbeatdown
39
Drives: '09 128i
I use a magnetic mount....
Works with ANY case and is very strong. Does not interfere w/ data or anything
http://www.amazon.com/Okra-Universal...vent+car+mount
      03-17-2015, 02:33 PM   #4
feeshta
58
I already have a magnetic mount system. Sorry if that was not clear from my original post. It's called the Wallee, and it looks like this.
It's a case that combines with different magnetic mounts for different purposes. I have the car mount pictured, and a couple of the stick-on disc mounts that I could use if there were a convenient location in the car.
The problem is that my car apparently does not have streaming Bluetooth capability, so streaming my music to the car is not possible without connecting to the USB port either with a cord or a wireless adapter. With a wireless adapter, getting power to the phone for longer trips is still an issue due to the placement of the power sources well away from the windscreen.
Ideally I think I need a way to mount the phone in a place where I can get a USB cord attached to the factory USB port. I would be perfectly willing to modify my car mount, etc. Just don't want to tear up the interior of the car if at all avoidable.
      03-17-2015, 02:47 PM   #5
MuNkY6913
The Crowing
MuNkY6913's Avatar
111
Drives: BMW 135i
2009 135i  [8.00]
I use mountek ngroove. Its also magnetic and inserts into the CD slot.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      03-17-2015, 02:51 PM   #6
feeshta
58
Hmm, that might actually work. I will have to look into that. I'm very unlikely to get all nostalgic and break out the old CD collection.
      03-17-2015, 03:07 PM   #7
MuNkY6913
The Crowing
MuNkY6913's Avatar
111
Drives: BMW 135i
2009 135i  [8.00]
The only draw back I've seen is sometimes it can get loose and wiggle around. Easily fixed by tightening it. It does come with plates for phone or tablet. I have both under the cases and it holds.
Mountek nGroove Snap 3 Magnetic CD Slot Car Mount for Smartphones and Phablets https://www.amazon.com/dp/B00MNXAFQ6..._yKicvb1GY1WGY
      03-17-2015, 03:09 PM   #8
feeshta
58
The million dollar question for a person like me might be this one. Does it squeak? Rattles and squeaks drive me batty, so I'm hoping it does not do that.
      03-17-2015, 03:15 PM   #9
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
I "mount" mine in the removable cup holder.
Pyrat 21417.50
      03-17-2015, 04:09 PM   #10
MuNkY6913
The Crowing
MuNkY6913's Avatar
111
Drives: BMW 135i
2009 135i  [8.00]
Never heard a peep over the past year.
      03-17-2015, 04:17 PM   #11
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
Cup holder.
2012 BMW 128i 6MT Deep Sea Blue Metallic
      03-17-2015, 06:32 PM   #12
yakuza70
yakuza70's Avatar
17
Drives: 2011 135i coupe
I use the Kenu Airframe mount. It simply fits onto the air vent in the center of the dash.
2011 135i DCT, M Sport, Deep Sea Blue
      03-17-2015, 08:05 PM   #13
631twentyeighteye
631twentyeighteye's Avatar
198
Drives: 08 335i
A holder that slides into the CD insert slot like this
http://www.amazon.com/Mountek-nGroov.../dp/B004G1L52Q
I don't leave it there since it blocks a decent bit of the radio screen but it works for when i need a GPS. If i were to do it again i'd probably go along the lines that Yakuza did, with one that clips onto the air vent.
08 e93 335i MT
      03-17-2015, 08:22 PM   #14
chris82
chris82's Avatar
827
Drives: 128i
2009 BMW 128i  [9.80]
If you have the smoker's package, you can open the ash tray lid and that leaves an absolutely perfect spot for a phone to lay there sideways. Doesn't move in turns or braking / accel either.
      03-18-2015, 09:03 PM   #15
PA135i
PA135i's Avatar
968
Drives: 08 135i 08 CR-V
I have a vent mount I bought from Griots garage. Works well on the center vent.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
      03-18-2015, 09:42 PM   #16
galois
Drives: 2017 340i xdrive; 2009 135i
I have a Kuda mount (link below) which sits nicely just below the vents (doesn't block air!). I already had an HTC car dock for my phone, so I just took off the plastic/suction and screwed it onto the mount.
http://www.kudausa.com/bmw-1-e81e82e...ack-a1345.html (gps thing is not included, it's just the leather covered mounting spot)
I do have bluetooth, but for USB (for power), I've routed the cord past the vents and then tucked it up under the center console so it is out of the way. I think there's a DIY on that in here somewhere (found it, it's for an F20 but same idea: http://f20.1addicts.com/forums/showthread.php?t=702457 )
Works very well, but was admittedly kind of expensive.
      03-18-2015, 10:05 PM   #17
E82.Love
E82.Love's Avatar
51
Drives: E82 128i AW
I just throw mine in my cup holder on the side
E82.Love | Magnaflow | aFe | H
      03-18-2015, 10:22 PM   #18
MuNkY6913
The Crowing
MuNkY6913's Avatar
111
Drives: BMW 135i
2009 135i  [8.00]
My g3 doesn't fit in the cup holder. Don't need to see the radio screen. I leave the phone there all the time. Best thing would be for someone to make a tablet trim piece that replaces the radio. Seen one for the 3 series. Not for the 1 though.
      03-19-2015, 07:55 AM   #19
RoundelM3
RoundelM3's Avatar
1837
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
I leave mine in my pocket, where it belongs.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      03-19-2015, 07:56 AM   #20
spinnakerflying
Drives: 2016 328i, 2010 135i
+1
      03-19-2015, 08:16 AM   #21
ejm3
200
Drives: 2012 135 Convertible 6MT
I use some cheapo vent mount thing and it works fine.
2017 Acura MDX
      03-19-2015, 04:50 PM   #22
TJ710
TJ710's Avatar
35
Drives: 2011 135i
Good answer.
1addicts
