      03-15-2015, 09:23 PM   #1
..'s Avatar
62
Drives: 135i
"Attn. Engine start"
Hello, all.
So it seems I now can not start my car without turning on the ignition first. Car starts up perfectly and currently has no codes. Idle is smooth and perfect also.
It's a 2008 135i MT with 64k miles.
The car sat for most of the winter with no tender so I'm assuming it is the battery?
My local Indy shop thought it might be my key so I tried my spare and same result.
Here is the picture for reference:
08' Sparkling Graphite Metallic E82 135i. 6spd Manual.
      03-15-2015, 09:37 PM   #2
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
Try disconnecting the battery for awhile and then reconnecting it to do a hard reset
2012 BMW 128i 6MT Deep Sea Blue Metallic
      03-15-2015, 10:01 PM   #3
Downeaster1
BMW Master Tech
Downeaster1's Avatar
587
Drives: E30, E36, E82, E90, F10, F80
This. Doing a "battery reset" will fix many issues (weirdly enough).
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad
      03-15-2015, 11:24 PM   #4
..'s Avatar
62
Drives: 135i
Thanks guy will give it a try and report back.
      03-15-2015, 11:47 PM   #5
twinboost_MD
twinboost_MD's Avatar
19
Drives: AW 135i
After you disconnect the battery go back in the car and press on the brake for a little. It will take out most of the residual power out the lines. Wait for 12 hours 24 to be safe before hooking it back up.
E46 M3 ---> AW 135i on Coral Red - JB4 w/MHD Backend - Alpina B3 - Koni Yellows - H&R Super Sport Springs - Powerflex Rear Upper Shock Mounts - ///M Strut Tower Bar
1addicts
