BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      03-10-2015, 11:43 AM   #1
debom3
35
Drives: 1997 M3, 2008 E90 M3
Fuel Pump Malfunction Troubleshooting Help
Hey Everyone,
Couple of nights ago I noticed that when the car started up it was idling pretty rough. Idle was bouncing maybe +/- 100 RPM's. Once it warmed up, everything seemed OK. About 1 mile down the road, getting onto the freeway I give it a little gas in 4th gear (revs were not very high) and I feel a studder. Chime sounds and the iDrive screen is flashing "Fuel Pump Malfunction" The car automatically goes into limp mode with the redline reduced.
I continue to my destination, and shut the car off. I turn it back on, and it appears that the car is OK. No CEL, or SES is on at restart.
I go to dinner, come back to the car and restart a couple hours later. Immediately I get a CEL and it says "INCREASED EMISSIONS". Going home, and getting on the freeway at about 30% throttle I get the same "Fuel Pump Malfunction" screen on iDrive.
I got an OBD2 scanner. Nothing fancy, just a cheapo from Walmart.
Codes were as follows.
P0092 - Fuel Pressure Reg 1 Control Circuit High
P0191 - Fuel Rail Pressure Sensor Circuit Range/Performance
P0193 - Fuel Rail Pressure Circuit High Input
P2288 - Injector Pressure Control too High
P3006 - Fuel Pressure Pressure Rate Controlled, Pressure Too High
As a good forum member, I have been searching for two days now. It appears that this is one of three things...
A - Low Pressure Sensor
B - EKP Module
C - Fuel Pump (maybe?)
Car is a March 08 Build, so it falls within the range of the vehicles that are known to have the EKP modules go bad commonly.
However, I found that people with P0191 claim that just replacing the Fuel Pressure Sensor fixes their issues.
My plan is to replace the Fuel Pressure Sensor tonight, clear the codes, and restart and see what happens. Im really hoping this fixes it because this is the cheapest option.
Does anyone have any insight into my issues? I would rather not waste the $$$ Replacing the sensor if someone can tell me that it is definitely the EKP module or something else...
I appreciate the help!
2008 E90 6MT M3--------------------1997 E36 5MT M3
      03-10-2015, 10:27 PM   #2
debom3
35
The pressure Senser seems to have fixed my isses!
Appreciate 2
      03-10-2015, 11:36 PM   #3
BzsBimmer
BzsBimmer's Avatar
3285
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Well that's a howdy doody! Don't even give us a chance to post wild ideas for you to throw money at lol.
I was going to say that your logic made total sense. With the absence of a good technician and more expensive diagnostic equipment, I too would have started with the lowest cost option to fix.
Great job!
      03-11-2015, 12:17 AM   #4
debom3
35
Thanks! I was pretty worried it was going to be something major. I feel I got lucky with the easy fix.
It was kind of frustrating, just getting the car of my dreams. Week 1 need a battery replacement $300, week 2 CEL goes off.
I was sooooooo relieved that it was only the sensor, simple fix, no coding required.
      03-11-2015, 12:38 AM   #5
Flea7
Flea7's Avatar
112
Drives: E92 M3 6MT/F48 X1/F430/F12
2016 X1  [0.00]
2008 E92 M3  [0.00]
2005 Ferrari F430  [0.00]
2014 Ferrari F12 Be ...  [10.00]
Thanks for the help through PM debom3.... Glad everything worked out well for you!
      03-11-2015, 01:29 AM   #6
regular guy
427
Drives: Sprint car
Originally Posted by debom3 View Post
Hey Everyone,
B - EKP Module
P0092 - http://wiki.rcollins.org/core/index....r:_2722,_P0092
P0191 - http://wiki.rcollins.org/core/index....r:_27CE,_P0191
P0193 - http://wiki.rcollins.org/core/index....r:_2786,_P0193
P2288 - http://wiki.rcollins.org/core/index....r:_2788,_P2288
P3006 - http://wiki.rcollins.org/core/index....r:_2787,_P3006
      06-15-2015, 11:36 PM   #7
Darkmoyle
Darkmoyle's Avatar
20
Drives: 2008 E90 M3
Hi Debom,
I am having the same symptoms you had. Can you share the part number/cost of the fuel pressure sensor?
Thanks for your great write up.
MD
      06-16-2015, 12:18 AM   #8
BPMSport
BimmerPost Supporting Vendor
BPMSport's Avatar
3387
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Replace the fuel pressure sensor first. Clear faults and then troubleshoot from there if issues persist. 80% chance it will rectify these issues.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      06-16-2015, 11:39 AM   #9
chief
chief's Avatar
208
Drives: 2008 Melbourne Red M3 Coupe
2008 BMW M3  [9.51]
Having replaced all three, the EKP solved the issue for me.
      06-16-2015, 12:44 PM   #10
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
I have an EKP module here if the sensor doesn't do the trick. Fortunately the module is extremely easy to swap out.
      06-16-2015, 01:19 PM   #11
debom3
35
Part No. 13537614317
If I recall correctly it was a little over $100 at the dealership with a BMWCCA discount.
Whoops, i guess you cant post links here...
Good Luck!
      08-25-2015, 12:40 PM   #12
slimmj0k3r
Drives: 2011 535i & 2013 Elantra DD
Just to bump this thread up I'm having the same issue, replaced the sensor and did the EKP module last night. Same issues this morning driving to work. Should I test the fuel pump wiring/relay before purchasing the fuel pump?
      01-25-2016, 07:01 PM   #13
Weyne Masters
Brazil
79
Drives: M3 LIME ROCK VT2-625
New updates?
      07-31-2016, 08:45 AM   #14
Janusbuxbom
Drives: E93 m3
Hi guys
I am having the same problem with my 08' e93 m3... But can't finde the ekp unit in the car?
Can Any of u help me??
Janus
      08-01-2016, 05:42 PM   #15
debom3
35
Originally Posted by Janusbuxbom View Post
Hi guys
Janus
I believe it is behind your back seat, but I have never personally taken one out.
      08-01-2016, 06:11 PM   #16
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Hi guys
Janus
This is correct. It's right behind the passenger side rear seat next to the door panel. The plug housing is green if I recall correctly. You can't miss it, right at the top and the only module in there.
I have a replacement in stock if anyone is looking for one.
      08-08-2016, 09:32 AM   #17
Janusbuxbom
Drives: E93 m3
Thanks what do u want for the ekp module? Do u ship to Denmark?
      03-27-2020, 12:00 PM   #18
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
+1 for low fuel pressure sensor replacement being the likely solution on this.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
m3post
