03-09-2015, 02:31 PM | #1 |
209
Rep 893
AutoEnginuity Service Reset Tool
I realize there are many posts on the subject of battery registration... but this looks to be the least expensive option for doing so... and I'm wondering if anybody here has experience with one?
https://www.autoenginuity.com/order-...eset-tool.html AutoEnginuity tells me (email) this works on an N55 (MEVD17KW). I could wait for BT to update their Scan Tool, but I drive a June 2010 build car with the OE battery and I'm thinking I need to be prepared. |
03-09-2015, 02:42 PM | #2 |
4338
Rep 6,196
I wonder how that would work with the battery coding?!?! It only has a one button reset function??!?
I have heard the BMWhat coding tool can code batteries now as well. Plus the bonus of doing all sorts of different coding! I have not confirmed this for myself however. |
03-09-2015, 02:46 PM | #3 |
209
Rep 893
That's my understanding as well. But I'm looking for the *least expensive* option... and as a guy with only a dumb phone, having to buy a cheap tablet and then the BMWhat app exceeds the cost of the AutoEnginuity tool.
It does two things: register a new battery, and reset oil service. $130 is a lot of money for one thing (my BT tool will do everything else), but I feel like I need this. |
03-09-2015, 03:06 PM | #4 |
4338
Rep 6,196
Just not sure how it will code a new battery. Is all that is involved in coding a new battery is telling the car "there is a new battery"?
The oil life can be reset easily buy holding the odo reset button. |
03-09-2015, 03:19 PM | #5 |
209
Rep 893
This comes from doc I have from AutoEnginuity (repeated here without permission):
"By running the Battery Registration, the vehicle controllers now know about the new battery. When you run the Battery Registration the following happens: • Saved temperature statistics are cleared. • Current Odometer reading is stored. Previous replacement readings are retained in the controller (last seven?). • Saved battery statistics are cleared (voltage, charge level & current). • Battery capacity reset to 80%. " |
03-12-2015, 01:32 PM | #6 |
368
Rep 3,547
NCSExpert Battery Registration
The attached describes the process using the NCSExpert code set - runs on a laptop and interfaces via a special cable with the OBDII port. I don't understand the references to temperature and other things. You need use NCSExpert to change the size or type of battery and Tool32 to say it is a new battery. If you don't change size or type, you just run Tool32.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
03-12-2015, 01:47 PM | #7 | |
209
Rep 893
03-12-2015, 06:36 PM | #8 |
368
Rep 3,547
I haven't registered a battery yet but I've programmed my car so the top goes down with the remote and a few other things. There are tutorials and I always pulled one out before proceeding. The first step is to back up your car's programming. If you do this, you should always be able to go backward. If it wasn't for the crytic commands - probably has something to do with the software being in German - it wouldn't be bad. All you do is load the area you want to modify into a word processor, modify it, and reload it. That is for NCSExpert. The battery registration seems very safe - just issue a command. I wouldn't blame anybody for wanting to have a way to do it that was simpler, however.
03-12-2015, 06:55 PM | #9 | |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
But I do have a tablet (that I inherited from my brother when he upgraded his tablet ).
