03-01-2015, 11:45 AM | #1 |
40
Rep 210
Aftermarket Amp?
Has anyone done an aftermarket amp upgrade? if so, what did you use? I'm having some issues finding info on people upgrading their F80/F82. I upgraded to the BavSound Stage1's a while back but I'm looking for a bit more punch...
I'm guessing I can't just buy an OEM HK amp and change out my Hi-Fi amp right? (Thinking it should be relatively plug and play with the same proprietary connectors, etc) |
03-01-2015, 12:22 PM | #2 |
715
Rep 1,529
Drives: e46M3 Ruby, Porsche Cayman GT4
Subscribed to this, I have the exact same question
03-01-2015, 04:33 PM | #4 |
92
Rep 290
Here's what i did on my f30. I'm hoping the trunk specs are the sane in the M3 so I can transfer my work. I carpeted the rest and put metal grills on. I'll post pics of the finished product but it works perfect and i lost 0 trunk space.
03-02-2015, 10:16 AM | #5 | |
1860
Rep 2,104
As far as a bit more punch, depends what you mean by that. A trunk sub would definitely fit the bill, but you may want to start with the underseat woofers. The standard HiFi ones are pretty pathetic. You could replace them with a decent midbass, like a Jehnert or Gladen, or get the SWS sub (fitment will require a little cutting/mod to the underseat enclosure) and see how you like it. I'm not sure how low the BavSound mids play, but the SWS may be what you want. In any case, start with the amp. Changing the anemic factory amp may be all you want. |
03-02-2015, 11:27 AM | #6 |
2712
Rep 2,371
That looks the same as my F82 trunk. Can't confirm measurements, but from the pic it looks the same.
2015 Black Sapphire Metallic 6MT M4
03-02-2015, 11:34 AM | #7 |
92
Rep 290
Here's the final product. I was planning on doing 1 piece of rectangular metal to make it look more flush but i got lazy. Just a trunk, so it was good enough for me. The thump was the most important part...which i have.
03-07-2015, 11:10 AM | #8 | |
144
Rep 216
Drives: 2017 BMW M2
Don't bother with an upgrade to the HK amp, it's not enough power.
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
03-07-2015, 12:45 PM | #9 |
23
Rep 140
03-07-2015, 01:09 PM | #10 |
92
Rep 290
Thats my alpine amp on the right side there. The other amp is the bmw stock amp. I just tapped into the lines to power my sub and put my amp where u see it. Those are 8" subs. Unless you're looking to win contests its plenty of thump.
03-07-2015, 01:27 PM | #11 | |
2288
Rep 13,001
In case I misunderstand what you wrote, you should not be tapping anything on that Combox harness -regardless if it works for you. |
03-07-2015, 04:11 PM | #12 | ||
92
Rep 290
Thanks for the heads up! |
