02-19-2015, 10:40 PM | #1 |
22
Rep 108
ECU pulling lots of timing in cylinder 5
Hey,
I've tried multiple tunes on this car (cobb OTS Stage 2 93, Cobb OTS E30 and my own custom E30 tune starting with Cobb's OTS E30 as a base) and they all result in the same issue. Lots of timing pulls in cylinder 5. Every other cylinder usually has very minor or 0 corrections. Car has BMS DCI and Chargepipe, Mech Tuning 5" IC, VRSF catless DP and a custom catback. I already swapped injectors, ignition coils and spark plugs with cylinder 1 which never had any corrections and it still stayed in cylinder 5. Logs attached. Any help is much appreciated. |
02-20-2015, 06:44 AM | #2 |
340
Rep 1,293
I seem to recall someone mentioning that you are more likely to see timing pulled on cylinder 5 do to the location of the where the PCV valve dumps into the intake manifold. The theory being that the oil vapors coming from the crank case lowers the octane in cylinder 5. I can't confirm this, but it may give you a place to start looking. In other words, you may have a bad PCV valve?
02-20-2015, 12:28 PM | #4 | |
Boost
1354
Rep 3,693
Drives: 135i M-Sport
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
02-20-2015, 12:43 PM | #5 | |
22
Rep 108
1st replace plugs 2nd replace pcv 3rd walnut blast |
02-20-2015, 12:49 PM | #6 |
Boost
1354
Rep 3,693
Consider swapping coils and possibly replacing valve cover as PCV channels may be clogged.
02-20-2015, 02:11 PM | #7 |
22
Rep 108
02-23-2015, 11:43 AM | #8 |
Joint Chiefs of Staff
24238
Rep 190,879
As mentioned above cylinder 5 is very sensitive to timing drops and unfortunately there is no fix to it at the moment. you either ignore it at your own risk or run a more conservative map.
Im having problems seeing your log so i cannot tell how bad these drops are. It would be very helpful if you can post it on datazap
02-23-2015, 02:56 PM | #9 |
22
Rep 108
Just to keep this updated, in the event I find a fix. Didn't change anything with the car and decided to do a couple logs over the weekend. Only difference is it's much warmer than the previous days I logged.
In terms of the results,h alf of the logs were completely clean and half had -3 degrees of timing in cylinder 5 from ~5300RPMS with it tapering of to 0 by redline. So it's much better for no reason besides the warmer temps .... sigh!!!! I'm installing upgraded PCV tomorrow. |
02-27-2015, 09:58 AM | #11 |
4919
Rep 115,990
02-27-2015, 10:33 AM | #12 |
22
Rep 108
03-03-2015, 09:05 AM | #13 |
22
Rep 108
Changed valve cover gasket and went back to E30. Logged and no corrections in cylinder 5. I tune myself, so started increasing load. Went to log and there are corrections in cylinder 5 again .. sighhhhhhhh
03-03-2015, 09:16 AM | #14 |
456
Rep 6,478
My *guess* has always been that's it's the cylinder which sees the most direct airflow from the manifold. The stock intake mani is awful, i'd love to see flow distribution by cylinder but a quick once over shows that it's far from optimal. Cyl 5 is almost always the noisiest on these motors.
What do the other cylinders look like? What does the global timing curve look like? Some corrections across a single cylinder are not at all uncommon, and don't mean anything is "wrong" automatically.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-03-2015, 09:33 AM | #15 | |
22
Rep 108
The other cylinders have 0 corrections. |
03-03-2015, 10:43 AM | #16 | |
456
Rep 6,478
That's speculation on my part, to be clear. If you are only seeing corrections on Cyl. 5 and global timing looks good, you are probably just fine. A log with 0 corrections at any point across any cylinder is tough to pull off on the street.
03-03-2015, 11:08 AM | #17 | |
22
Rep 108
03-09-2015, 09:55 AM | #18 |
22
Rep 108
Update:
I changed valve cover gasket and still had the same problems. After some reading, I decided to make some VANOS Intake and Exhaust changes which so far is yielding positive results. Logs attached. |
03-17-2015, 01:22 PM | #20 |
92
Rep 181
What sort of changes did you make Cpt?
03-17-2015, 03:05 PM | #21 | |
456
Rep 6,478
Again going back to my theory (it's not "mine", just what I believe to be the root cause), i'd imagine it's an airflow issue. CYL. 5 gets fed the most direct charge relative to the other cylinders. So curious what you did on the VANOS side.
03-18-2015, 09:52 AM | #22 |
22
Rep 108
What works best for me was advancing the intake degrees so that it opens earlier and reduces the Intake/Exhaust overlap. Pic of my changes attached.
