02-12-2015, 07:26 PM | #1 |
Rep 84
Aluminum Flywheel = Vibration under 2k RPM?
Current mods:
AKG solid motor mounts Race tranny mount with enforcer cups Race rear subframe bushings I installed: spec 2+ clutch, spec aluminum flywheel, tranny refresh kit from ECS, redline MTL fluid. After install: Harsh vibration from 1.5k rpms to 2.5k rpms ONLY under a harder throttle. IE: over 50% pressed If I don't hit the gas hard, no vibration. In 3rd gerar + no vibrations in any rpm or throttle. Anyone have experience with this? Is this just a case of letting the clutch break in?
DCI | JB4 | DPs | AAW IC | Motor / Trans / Sub Frame Mounts | UUC Short Throw | Swift Spec-R Lowering Springs & Koni Yellows | EBC YellowStuff Pads
02-12-2015, 09:03 PM | #2 |
34
Rep 632
Yeah man, that's what single mass flywheels do. It's normal!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
02-15-2015, 04:13 AM | #3 |
21
Rep 169
02-15-2015, 04:41 PM | #4 |
11
Rep 150
Yup. I was prepared for the rattle etc, as everyone talks about it, but the vibration issue freaked me out, since nobody ever mentions it. It isn't just spec, its all SMFW as far as I can tell. I have a custom one made locally and its the same.
03-22-2015, 05:04 PM | #5 |
Rep 84
Does anyone else have a screetch when they move off from first slowly? Maybe not a screetch but its def. a sound from the clutch disk and flywheel contacting each other.
03-23-2015, 10:27 AM | #6 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Clutch chatter is also normal......
2014 M5 6MT
03-23-2015, 12:36 PM | #7 |
Rep 84
ahh Didn't know thats clutch chatter.
I was associating rattling of the gears to clutch chatter then. Doesn't bother me long as its normal!
