01-22-2015, 12:18 PM | #1 |
1400
Rep 761
M4 Trunk closing springs adjustment?
Several people have mentioned having difficulties closing the trunk lid on the M4 due to its much lighter weight compared to the M3 trunk lid.
I recently signed up for 24 hours of BMW TIS to check out some schematics, and whilst browsing I noticed that the springs for the trunk lid have 3 different position settings - heavy, medium and light. I was wondering if BMW didn't think to set the springs in different positions for the M4? There is a fairly simple looking adjustment procedure which involves taking off the side liners in the rear luggage area and moving the end of the spring to a different slot. Has anybody tried this adjustment, or got their dealers to do this? |
01-23-2015, 08:22 AM | #5 |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
I like the old trunk better. When popped it stayed closed so the whole world doesn't see your shit in the trunk and when closing you could just let it drop. It also felt heavier and more substantial. New trunk just feel no different than a Camry
01-23-2015, 08:29 AM | #6 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
The official carbon fiber trunk spoiler installation procedures advises the trunk springs be adjusted after the spoiler is fitted. I think they believe it adds just enough weight to affect the closing of the trunk. I installed the spoiler w/o adjusting the springs with no issues.
LIVE FAST..DRIVE FASTER!! |
01-23-2015, 08:30 AM | #7 |
74
Rep 302
Drives: 2017 i8 coupe
Garage List 2014 Ferrari 458 Sp ... [10.00]
2013 Toyota Tacoma [0.00] 2015 BMW 228i [0.00] 2015 M4 Convertable [10.00] |
My M4 vert has an electronic closing which draws the trunk closed for the final inch or so.. Really like that feature, should be on E80 and 82
"AY Brave!"
01-23-2015, 08:33 AM | #8 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Everybody wants beefy doors, heavy trunks lids, bulletproof skid plates, a 3200lbs car, for under $70k. BMW can't win here. lol...
01-23-2015, 09:46 AM | #9 |
183
Rep 2,872
I've stood there complimenting and going on with an owner about how much I love the i8. They'll make sure to mention the CFRP Tub Frame and how light it is and in the same token mention its impossible to get in and too low
01-23-2015, 01:48 PM | #10 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
The M4 trunk lid is made from plastic, not metal, for weight savings. That's why is doesn't feel heavier or more substantial - by design.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
01-23-2015, 01:58 PM | #11 |
Member
74
Rep 379
OP, PM me screen shots or a PDF of what the procedure is and Ill try it on my M4 this wknd.
01-23-2015, 04:27 PM | #12 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
01-23-2015, 04:37 PM | #13 | |
10785
Rep 8,852
Carbon-fiber-reinforced polymers (CFRP) are composite materials. In this case the composite consists of two parts: a matrix and a reinforcement. In CFRP the reinforcement is carbon fiber, which provides the strength. The matrix is usually a polymer resin, such as epoxy, to bind the reinforcements together.[1] Because CFRP consists of two distinct elements, the material properties depend on these two elements. The reinforcement will give the CFRP its strength and rigidity; measured by stress and elastic modulus respectively. Unlike isotropic materials like steel and aluminum, CFRP has directional strength properties. The properties of CFRP depend on the layouts of the carbon fiber and the proportion of the carbon fibers relative to the polymer.[2] Despite its high initial strength-to-weight ratio, a design limitation of CFRP is its lack of a definable fatigue endurance limit. This means, theoretically, that stress cycle failure cannot be ruled out. While steel and many other structural metals and alloys do have estimable fatigue endurance limits, the complex failure modes of composites mean that the fatigue failure properties of CFRP are difficult to predict and design for. As a result, when using CFRP for critical cyclic-loading applications, engineers may need to design in considerable strength safety margins to provide suitable component reliability over its service life. Don't slam your trunk lid on an M4 - it might break!!
01-25-2015, 06:09 PM | #14 | |
1400
Rep 761
I just paid $30 for a 24-hour access to this web site: https://www.bmwtis.com/ The springs are shown in this parts diagram http://www.realoem.com/bmw/showparts...19&hg=41&fg=60 By default, the end of the springs nearest the tail light hooks into a Z-shaped slot in the body panel, which provides 2 of the adjustment positions. There is an additional diagonal slot in the panel which you can also move the spring to - this is either the 'light' or 'heavy' position (can't remember which!) I had a look, but can't find a diagram of this part of the bodywork on the parts web site :-( The adjustment procedure was very brief and basically came down to: 1) open trunk 2) remove side trunk liners 3) have somebody support the trunk lid 4) wearing gloves, grab the end of the spring and move it to the desired slot 5) see if trunk closes better! The only caveat was to make sure that the left and right spring positions didn't differ by more than one (to avoid warping the trunk lid). Hope this helps! |
01-25-2015, 09:29 PM | #15 |
Member
74
Rep 379
^ ill give it a try on Monday or Tuesday and report back.
09-17-2015, 11:12 AM | #16 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
Did anybody ever try this? @Time ?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
