XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      01-16-2015, 08:28 AM   #1
hessan
18
Drives: 2003 z4 2.5
Highest height tire to be used on 18" wheel
I currently have factory 225/45/18 . The roads here overseas are terrible and I wanted to go with non runflat. Can i use a higher sized tire for a less harsh ride? Like 50?
      01-16-2015, 09:11 AM   #2
Alfisti
6503
Drives: 2008 Saab 9-3 Combi
I purposely looked for a car with 17's. Modern cars don't have anywhere near enough tyre for snowy/icy climates and the resulting pot holes.
225/50 is a real nice profile, not too old school but enough tyre to get it done. I run that combo on both our X1 and 9-3.
      01-16-2015, 09:43 AM   #3
hessan
18
Drives: 2003 z4 2.5
Can I do that on my 18?
      01-16-2015, 11:50 AM   #4
DarrenBM
Drives: X1 2.0d xDrive SE
I wouldn't use a 50 profile tyre on an 18" rim. It will slow acceleration and throw out the speedometer a bit too, making it appear you are travelling slower than you actually are. It may also affect other things like ABS.
I'd rather switch to a 17" rim to fit a 50 profle tyre
      01-16-2015, 11:51 AM   #5
Twix
Twix's Avatar
657
Drives: 2011 e91
My summer tires have an overall height 1/2" taller than factory. Other than the speedo being out by 3 kms, it's fine.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-16-2015, 12:57 PM   #6
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
The speedos read so ridiculously high in our cars from teh factory anyway, it will be an improvement.
Acceleration is not noticeably affected at all by a couple % change, so I wouldn't sweet that.
OP, are you still on runflats? Getting off of those god forsaken things goes a long way too.
      01-16-2015, 01:30 PM   #7
annoyingmouse
Drives: bmw x1 xdrive28i
If you're replacing run-flats with non run-flats, then the lower weight could help offset some of the inherent rotating mass gain from expanding the circumference. Run-flats do tend to weigh more at any given size.
Also, the speedometers seem be off anyway, and a greater circumference could actually help that.
      01-16-2015, 02:07 PM   #8
Red Bread
4463
Drives: Smog machines
Yep, a bigger tire will actually correct the speedometer. I accomplished this by going wider with the same aspect ratio with my old car. No harm in going to a 50 series tire, as there is plenty of clearance on a stock X1.
      01-16-2015, 02:38 PM   #9
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Speedometer and odometer can be corrected on our cars to match the real tire circumference and show actual speed. I did code different oem tires and now my speedo is off by 1 mph only with the original wheels and tires.
About the acceleration... Is it really be noticeable?! In theory yes but what about in real world?
I'm also planning to put higher profile tires when my rfts are done.
      01-16-2015, 05:29 PM   #10
fw_fw
Freude am Fahren
fw_fw's Avatar
108
Drives: 18 X3 xDrive30i xLine Phytonic
I'm about to buy tires in a couple of months and am having the same questions. Comparing 225/45/18 to 225/50/18 shows a 3.3% increase in circumference, therefore when the 45 series shows 60mph the 50 series will actually be going 62.1mph. I checked my X1 against a handheld GPS today, and the speedo was reading 60 when I was actually going 58 according to the GPS. So 50 series will actually correct it almost perfectly. That and the Michelin Pilot Sport A/S 3s are 30 bucks cheaper in 50 series I've about decided to go with the 50 series tire.
Current: 18 X3 xDrive30i
Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster
      01-16-2015, 07:01 PM   #11
Twix
Twix's Avatar
657
Drives: 2011 e91
Your speedo will read correctly with a taller tire, but keep in mind that the odometer is separate from the speedo. It will measure incorrect mileage.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      01-16-2015, 09:25 PM   #12
Alfisti
6503
3.3% is riiiiight on the cusp of being just OK. Ideally one would come in below that.
TBH unless you're leasing i would sell the 18's and buy a set of 17's. Even in summer the car will ride better. I was running 225/45 on my Saab and it handles BETTER with the 50's because it doesn't scamper and hop over ridges in the road, there's more compliance. Mind you the X1 craps allover the 9-3 for handling.
      01-16-2015, 09:53 PM   #13
Twix
Twix's Avatar
657
Drives: 2011 e91
If you want to put 44" tires on go for it, just as long as they all match in outer diameter.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      01-17-2015, 07:50 AM   #14
BeemerX1
Belgium
15
Drives: BMW
If you go with a non-runflat the ride will be a lot softer.
My 20" rims wit non-runflat on them (I think 225/35/20 or 225/30/20, not sure but) is a lot softer the my stock 18" rims with runflats (size you mention 225/45/18 ).
And I'm very happy with my Michelin Pilot Super Sports tires (on my summer set). :-)
      01-19-2015, 12:55 AM   #15
hessan
18
Drives: 2003 z4 2.5
which will give me more of a smoother ride ? a 245/45/18 or a 225/50/18
      01-19-2015, 09:13 AM   #16
Alfisti
6503
basically the same but no way in the world i'd run 245's.
      01-19-2015, 09:35 AM   #17
BeemerX1
Belgium
15
Drives: BMW
The Wheel Fitment, Tyre Stretch, Rolling
Radius and Speedometer Error Calculator
http://www.willtheyfit.com/
But I still don't understand why you go with other fitment then stock, just ditch the run flat crap and you got a much smoother ride.
I ride on 20" (non run flat) and sport suspension. I has a smoother ride then 18" with run flat and stock suspension.
(Of course now for winter I have my sport suspension and I need to ride with run flats on the 18" rims for the vehicle inspection.)
      01-20-2015, 02:06 PM   #18
BMWConvert
Drives: 2014 X1 xDrive 28i
I recently ditched the run flats for the Michelin Pilot Sport A/S 3s. I wanted a taller and wider tire so I went with a 245/45 18. No issues whatsoever. If there is any decrease in acceleration its very marginal. Speedo is dead on now.
      01-20-2015, 08:15 PM   #19
fw_fw
Freude am Fahren
fw_fw's Avatar
108
Just ran the numbers on your setup.....I like it!! Now let's see what Tire Rack has in this size.....
      01-21-2015, 11:53 AM   #20
Shredjim
Drives: 2014 x28 X1
I tried the Michelin PS AS/3's in 245/45/18. While the tire fit no problem, I ended up swapping them for 225/45/18's. The 245's had unbelievable grip and were very plush but made the car wander all over the road. If you are going to the track, 245 might be a good choice, but for normal driving 225 is a good size for a square set up. Wow, what a difference these Michelin tires are from the run flats!
      01-21-2015, 01:48 PM   #21
BMWConvert
I know that the Michelin PS AS/3's come in two different speed ratings. The higher speed rated tire has a stiffer sidewall. This is the tire that I bought and I also have them inflated to about 42psi. I have had zero issues with them wandering on the road. They track very straight and handle excellent.
      02-03-2015, 03:27 PM   #22
X135iM
X135iM's Avatar
Drives: 2015 X1 35i Msport
I put 50's on my 18's for winter tires and it is fine, only thing is, if the wheel is turned to maximum. and you hit a rut or bump at low speed it rubs the liner a little bit. Very minor issue.
15 X1 35i Msport LeMans Blau/Schwarz |Ultimativepaket|JB4
07 X3 Monacoblau/Grau Prämie|KaltemWetter|Komfort|Navigation
tschüss : ( 11 335d JBD Tiefseeblau/Oysterschwarz |Prämie|Navigation|KaltemWetter|Sportpaket
xbimmers
