12-20-2014, 02:03 PM | #1 |
Rep 12
Remote control triggers the alarm
This happened to me these two weeks. I have comfort access. When i try to unlock the car through comfort access or remote control it will triggers the alarm and reset the miles and time in the car. The alarms will clear itself after a while. Then i unlock the door through the key holes on the handle and start the car but it wouldn't start. After a couple of hours it would work again. i tried change battery for both of the remote control and also the battery for the m3, but it still doesn't solve the problem. When my friend came over to do a scan and it showed it as something to do with the control alarm module and CAS. I was wondering if anyone know how to fix this thank you.
12-24-2014, 04:07 PM | #6 | |
96
Rep 545
Using a Digital Volt Meter you can check the voltage drop on the positive and negative battery cables as a start. Voltage drop testing is a great method of finding circuit resistance for your diagnosis of the problem. You might also need a wiring diagram showing the supply wires and connectors for your vehicle. Here is an introduction to voltage drop testing: |
