12-17-2014, 03:36 PM | #1 |
22
Rep 214
Drives: 2012 E92 M3 ZCP 6MT AW/BLK
Diagnostic tool/programmer
Hello everyone
So I am planning on keeping my M3 for a very long time with old school maintenance as with all our BMWs. Shopping for an OBD2 scan tool that will work for my 2012 M3 but also for our other BMWs-2007 M6 cabrio, 2013 535i xDrive M sport and 2009 328i xDrive Coupe. Want something that will be able to reset service functions for example, allow battery registration, Valvetronic reset(N52 valve cover diy), and maybe allow coding as you could do at the dealer? Was looking at AutoEnginuity with BMW pack as I believe it can do it all except coding? Also could work for other cars? Any other somewhat reasonable cost tools out there? Looking to avoid the dealer as much as possible! Thanks
2012 BMW M3 ZCP 6MT |
12-18-2014, 07:56 AM | #5 |
22
Rep 214
BMWhat app looks interesting to start off with. Anybody know where to find the wifi piece?
12-18-2014, 09:23 AM | #6 | |
433
Rep 855
Assuming you are inquiring about the wifi model because you have a iPhone?
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
12-18-2014, 01:32 PM | #7 |
22
Rep 214
So what is the difference between the Bluetooth and wifi adapters? Looking to use on iPhone and iPad
12-18-2014, 06:02 PM | #8 |
433
Rep 855
If you have an apple device, you would have to use the wifi adapter.
For Android devices you would use the Bluetooth adapter. It's highly recommended to purchase their branded adapter as they claim 100% compatibility to the features in the app.
12-18-2014, 09:08 PM | #9 | |
22
Rep 214
12-19-2014, 06:33 AM | #10 |
898
Rep 3,071
Does anyone know of BMWWhat can show oil temp, pressure, true voltage, etc./ Torque can't but is also $52 cheaper.
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
12-19-2014, 10:30 AM | #11 | |
433
Rep 855
Torque can't show oil temp but can show voltage and manifold pressure
12-19-2014, 02:15 PM | #12 |
898
Rep 3,071
Thanks Jdamore. Will send them my session log
12-19-2014, 05:57 PM | #13 |
22
Rep 214
Want to see if it will code my heated mirrors to turn on. Wonder if the previous owner deactivated when activating the rear fogs. Passenger mirror also doesn't tilt in reverse no matter where the switch is.
12-20-2014, 08:25 AM | #15 |
14
Rep 198
12-20-2014, 11:17 AM | #16 | |
433
Rep 855
I suppose they could have disabled the mirrors.. But why? Coding is not needed to enable the rear fogs. The switch just needs to be modified.
12-20-2014, 12:20 PM | #17 |
433
Rep 855
Just checked.. There is the option to enable/disable tilt in reverse but didn't see the option for heated mirrors.
12-21-2014, 02:46 AM | #18 | |
22
Rep 214
12-22-2014, 06:35 PM | #20 |
Rep 12
Has anyone compared BMWhat against Bavarian Tech? What are the pros/cons to each?
I have an Apple device and a Win laptop, so I could go either way. At first glance, BMWhat seems like a cheaper solution with more features (coding) over Bav Tech. Am I missing something? |
12-26-2014, 05:05 PM | #21 |
22
Rep 214
So got the app and dongle and played with it a bit. Does this allow new battery registration?
12-26-2014, 05:09 PM | #22 | |
433
Rep 855
It also allows you to CODE the size and type of battery. Edit: i just realized it sounds like I work from them.. I do not! I'm just knowing the answers lol. I've also had communication with them lately and battery registration was one of my inquiries. To prove I do not work for them I will say they are are not coding the battery type and size correctly lol. They are coding the FRM which works but the correct way is to CODE the Vehicle Order number. If you ever get the car updated at the dealer, they will default all the coding to the VO including the battery specs. You'll have to fix it again to the battery specs you installed. No biggie but worth mentioning. I would recommend keeping the same battery as originally installed anyway. Last edited by jdamore; 12-26-2014 at 05:22 PM.. |
