12-15-2014, 12:16 AM | #1 |
26
Rep 325
Ssk installed: 5th and 6th difficult
Hey guys
I installed the ssk with the kink pointed toward the front of the car and pointed to the rear... Fifth and sixth is still difficult and does not re-center itself into neutral The only way I think I can figure this out is if I have someone shift the gears while I am underneath to see if it rubs or hits anything I have a feeling maybe 5th and 6th are just difficult gears 1,2,3,4 seem to be amazing though! Thoughts please!
Mods: Clutch stop, BMW performance SSK, BMW PE exhaust, CDV delete, Clutch pedal spring delete (CPS delete) : ) - check out the the DIY:http://www.1addicts.com/forums/showthread.php?t=1122797
12-15-2014, 02:39 AM | #2 |
European Editor
10589
Rep 22,992
It might just be time for a test drive. Can you engage reverse gear? That is always the hardest one to get into - post ssk. The shifter will get slicker with some mile in it.
12-15-2014, 01:03 PM | #4 |
26
Rep 325
BMW performance
12-15-2014, 01:35 PM | #5 |
55
Rep 182
I just installed the same thing, it was a pain since you have to remove the midpipe and shields to install the carrier. There is a increase in shift force (likely 80/55~146%) for all gears. I have not noticed anything particularly hard about 5th and 6th though.
When is the last time you changed transmission fluid? May be worth a try. |
12-15-2014, 01:41 PM | #6 |
26
Rep 325
Is it possible I bent the arm that goes from the tran. To the the shifter?
12-15-2014, 03:57 PM | #7 |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
I had similar issues where mine would get stuck in between the 5-6 gate which they solved by shaving it down a little. However mine is a OCC SSK which is a metal ball. I would think your BMWP would be a perfect fit.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
12-15-2014, 04:22 PM | #8 |
26
Rep 325
Shave what down?
Maybe I put too much grease and the ball is sitting too high? Would that make 5 and 6 rough?
12-19-2014, 03:30 PM | #9 |
449
Rep 2,058
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Sounds like you a. Installed incorrectly. B. Have some material/fabric from the shift boot underneath the knob restricting your shifts (look under you'll see what I mean, this also happened to me when I put mine in). C. Depending on what company makes the SSK, it needs to be lowered or customized a bit to work properly (also happened to me).
I bought a evo 3 a few months ago and had the dealer do it and they fucked it up. Had a small shop do it and helped the tech out while he was altering it and had it fixed up to my expectations👍👍👍
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
