12-10-2014, 08:26 PM | #1 |
Rep 27
E92 m3 engine knock, any ideas?
Hi everyone, I have a 08 bmw m3. After taking the car for high speeds, I started to hear engine knock coming from top of the engine. It almost sounds like a Diesel engine. While driving the car the knock appears at around 1800-2500 rpm in first 2 gears and 3rd gear and up its harder to hear. Next day I changed the oil and the filter and slowly drove it around the neighborhood. But the knock is still there... Few days later I started the car in the cold and heard few various knocks in the engine and it went away. Engine works perfectly tried raising RPMs still everything was fine. Once the car got warmer I start to hear knocking at about 2000rpms. Once it got to normal temperature it knocks anywhere from 1500-2500. The more RPMs I give it, the more knock I hear. The car has around 56k miles on it. Any ideas what that could be? Thank you
12-10-2014, 08:28 PM | #2 |
452
Rep 1,289
My first guess would be bad gas, but I've read too many threads on rod bearing issues, so I hope it's not that.
'16 ///M4 GTS
'11.75 ///E90 M3 ZCP | DCT '06 ///M5 | SMG - Gone '98 ///M3 | 5MT - Gone '07 ///M Coupe | 6MT - Gone |
12-11-2014, 02:30 AM | #4 |
2511
Rep 4,381
A knocking noise that is louder at ~2000-2500 rpm is indicative of high rod bearing wear/imminent failure.
Posting an audio clip of the noise might help to diagnose. |
12-11-2014, 12:23 PM | #7 | |
63390
Rep 24,680
Try to post a Video clip and stop "ASAP" with driving your car if you don't want a black hole in your engine block !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-11-2014, 01:20 PM | #10 |
22
Rep 184
How many miles are on it? Does the noise sound like it's coming from the top (valvetrain), or from the bottom (rod bearings). Also what RPM were you running at 180 mph?
12-11-2014, 01:25 PM | #11 |
63390
Rep 24,680
Read again the OP post => He has 56K on it .
12-11-2014, 02:26 PM | #13 | |
Rep 27
12-11-2014, 03:13 PM | #16 |
177
Rep 2,301
em....any ideas?
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
12-11-2014, 04:26 PM | #19 |
33
Rep 741
That's an expensive sound
What the heck are you driving at 180 mph for? You suicidal?
2010 BMW M3 vert with DCT & Akra (sold)
2012 Porsche 911 Turbo S |
12-11-2014, 05:14 PM | #21 |
111
Rep 531
Another one bites the dust.....
E92 M3 - Alpine White - Carbon Roof - 6 SPD - Speed Cloth - No NAV/EDC - Meisterschaft - Signature Forged |
12-12-2014, 04:56 AM | #22 |
2511
Rep 4,381
Yeah sadly a knock that becomes louder as you approach 2000 rpm is quite typical in cars with imminent crankshaft bearing failure...sounds more like main bearings but given the S65s history it could also be a rod bearing. You will very lucky if your crank is reusable.
