12-10-2014, 01:03 PM | #1 |
997.1TT
1004
Rep 1,672
Erratic idle after getting gas?
Tonight after filling up at the gas station, I pulled out, and stopped in traffic. When I stopped, I noticed my idle became erratic. It would drop down to a near stall (<300RPM's, then bounce back up over 1000RPMs, and level off around 600RPM's where it usually sits, then repeat. It did this about every 1 1/2 seconds, until I drove away, then it seemed fine the rest of the ride.
This pretty much scared the shit out of me, but then I remembered the guy I bought the car from telling me that you can't top these cars off, and if you do, if you stop after leaving the gas station (i.e. at a stop light) the car will stall, but it will drive fine if you leave immediately and don't stop (i.e. getting on the highway). I assumed this had to be the issue he was talking about, seeing as I could not replicate the erratic idle. For now, I will assume the car is fine, but I was wondering a few things: 1. I googled and this is apparently a HUGE issue with these cars. Several reports of this from one 5 page thread. Is what I am describing happened likely the cause of filling up at the gas station, or is there possibly another issue? 2. If it's just from filling up at the pump, what is the cause of this? This can't be "normal", so does this indicate that there is something wrong with the car, or is this a "characteristic of the car" and normal among most M3s? Thanks in advance. |
12-10-2014, 01:12 PM | #2 |
420
Rep 1,678
Drives: 2011 MCB E92 M3
You might want to have your idle control valve checked/replaced.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
12-10-2014, 01:18 PM | #3 |
Bad Lieutenant
233
Rep 3,517
Some members have had the purge valve in the fuel filter/tank replaced, some have had techron work and as mentioned above, the idle control pieces.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
12-10-2014, 01:19 PM | #4 |
63393
Rep 24,680
I've 32K on it, and I never had this after getting gas .
Maybe you should try another brand like Shell V-Power and see the outcome . When this happens all the time , than it's a question for your BMW/Dealer .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-10-2014, 01:26 PM | #5 | |
63393
Rep 24,680
When it's the idle control valve it happens frequent .
12-10-2014, 01:31 PM | #6 |
514
Rep 3,482
This happened to me only once, but it went away after only the first stop.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
12-10-2014, 02:01 PM | #7 |
57
Rep 384
This is a common issue. For me it's only happened once when (I assume) as you referenced, I topped off the tank to the very last drop. Check out this thread for some good info:
http://www.m3post.com/forums/showthread.php?t=953477 |
12-10-2014, 02:36 PM | #8 |
410
Rep 1,025
This happens to me almost every time I get gas in this car. I took it to the dealership and they claimed they couldn't reproduce it...Not surprising since they are pretty useless. It still happens.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
12-10-2014, 02:39 PM | #9 |
420
Rep 1,678
I've never experienced this, but I never top off since it's entirely pointless and can cause more harm than good.
12-10-2014, 03:48 PM | #10 | |
1020
Rep 1,486
Drives: 2012 e92 M3 DCT ZCP
12-10-2014, 05:34 PM | #12 |
83
Rep 468
12-10-2014, 06:29 PM | #13 |
8912
Rep 4,107
Had this issue, video posted in an older thread. Solved by replacing the fuel tank breather/vent valve...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
12-10-2014, 06:33 PM | #14 |
410
Rep 1,025
Yeah I need to get it looked at by a different, more reliable dealership...as well as the other problems. I never top it off..I just fill it up until it shuts off the first time.
12-11-2014, 12:23 AM | #15 |
997.1TT
1004
Rep 1,672
Thanks for all the help. The general consensus after reading every post in that 5 page thread, and reading the replies here is that it's the fuel tank breather valve that causes this.
Does anyone have any input on a DIY for the fuel tank breather valve, or any idea what the part might cost or where to source it (besides dealership)? I would like to get this fixed, but since it has only done it once and it's such a common issue, I don't see myself paying the dealership to do it. It seems simple enough and I am not about paying someone $500 to do something I can do myself for less than $100. |
12-11-2014, 06:49 AM | #16 |
997.1TT
1004
Rep 1,672
I had another slight issue today with my idle. Got in the car this morning after it had been sitting all night (cold start). The car idled around 1200 RPMs like normal, slowly dropped down to 800 or so after about 10 to 15 seconds like normal, then stayed there where I let it idle for about 45 more seconds. Everything up to this point was normal, but I revved it up to about 1500 RPMs for a quick second, and the RPMs dropped down to 500-600 instead of where they were at 800 (like on a normal cold start). Upon dropping down to 500, the car immediately began surging between 400 and 600 RPMs, up and down, over and over, about 2 or 3 surges per second. This lasted for about 10 seconds, then stopped.
I am slightly paranoid after last night, and am not sure if maybe this was related? I know these cars are finicky on cold starts (especially on cold days like today), so is this "normal" behavior for these cars? Every little thing the car does now I think there is something wrong with it (thanks to my erratic idle last night). |
12-11-2014, 08:57 AM | #17 | |
1020
Rep 1,486
12-12-2014, 12:28 AM | #18 |
12
Rep 339
I took my car in for oil + spark plugs and had my mechanic change the fuel tank breather valve.
I filled gas once so far and it didn't show the idle symptom. It happens about 50% of the time. He said the part is $80 but the labor is a lot more. |
12-12-2014, 09:18 PM | #19 |
Rep 1
This has happened to me as well, I've been able to duplicate it 5-6 times in a row. The key is to fill up, drive a few blocks, sit and let it idle with the ac on full cold. I've taken it to the local dealer 3 times and the first two I got the could not replicate excuse and no codes. Third time I showed them a video of it almost stalling in my driveway. This time, they found a fault that said I needed my throttle bodies cleaned, despite the fact that all 3 times I told them I need a new purge valve. they said that warranty rules with BMW say that they need to find a fault in a part or they can't replace it. Throttle cleaning costs me $360 by the way. Im going to fill it up tomorrow and let it idle. It has nothing to do with bad gas as I've tried several different stations. If it stalls again tomorrow I'm going to lose my mind and tell my dealer I'm going to another dealer because clearly he doesn't know how to fix my car. Is there anyone on here that got the purge valve replaced under warranty and if so, how did you get them to change it?
12-12-2014, 10:00 PM | #20 |
Waiting for the sun
66
Rep 704
I've had this happen a couple times in the last 6 mos or so, but it was not related to filling the tank. I get gas 90% of the time at the same place. It's just been random, so don't think it's a filter or anything like that and just chalked it up to ECU gremlins... Yes, I believe in gremlins.
2012 E92 M3- Miss her.
2015 F10 M5- Land yacht, but miss her too! 2016 991.1 GT3- Woohoo! 2018 M240ix- Daily driver. Still Woohoo! |
12-12-2014, 10:03 PM | #21 |
8912
Rep 4,107
I had this happen after filling up or with a 1/4 tank, did not matter as it seemed random. Digging through this old thread started by member gpitts is what led me to the solution...
2021 X3 M40i
12-12-2014, 10:20 PM | #22 |
Waiting for the sun
66
Rep 704
Interesting. Hasn't happened to me in a couple of months and I would think if it was fuel pump or pressure valve failing it would have gotten worse.
