EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      12-07-2014, 05:14 PM   #1
MasterC17
329
Drives: 2015 BMW M3
DIY: RW Carbon F8X Carbon Steering Wheel Trim
Here's a little DIY I put together for the carbon steering wheel trim as it doesn't look like anyone else has posted one and it's a bit of a pain in the butt.
1. Disconnect negative battery terminal using a 10mm socket/rachet. DON'T CLOSE THE TRUNK!
2. Grab a T20 Screwdriver (or if you don't have one something similar) and push straight through the hole on the left side of the steering wheel and push in the retaining spring (it will provide resistance) while also pulling up on the left side of the airbag. It might take a few seconds but you'll be able to pop the airbag out on the left side (compared to E46, 100x easier). Repeat for right side.
3. Now you will see the airbag connector at the back. Using a flat-head, push the connector down until you can pop it out. Put the airbag carefully aside.
4. Using your T20 Screwdriver/bit, remove the two bolts holding the steering wheel trim piece in.
5. Using your T20 Screwdriver/bit, remove the single bolt at the back, lower portion of the steering wheel holding on the steering wheel trim. Carefully remove the steering wheel trim (pull up and out).
6. Ok, now for the 'fun' part. Place your steering wheel trim upside down on a flat, protected surface and prepare to remove the six little (evil) metal retainers. I found it easiest to use a razor blade to get them started by wiggling it back and forth. Then follow with a small eyeglass flat-head screwdriver and a pocket flat-head to get them all the way off. Do this for all of them until the trim is loose, and then remove the inner trim from the outer (pull up and out).
7. Now that you got those dang metal retainers off, put your new fancy carbon trim insert into the outer trim portion. Time to put those metal retainers back in! First, use a small hammer to flatten the bottom edge down again. Now, you will have to use some pressure with your fingers to get them started back onto the trim prongs. Next, use a 5mm 1/4 socket to put over the metal retainers, and again use your little hammer to hit them down until they are all the way on. Congrats, the new carbon trim is on and secure!
Installation is the reverse of removal. Don't forget to clip the airbag connector back in! And to put the airbag back on just use your hands and put pressure evenly on the airbag until it pops back in. Congratulations, your interior just became even more expensive!
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
Appreciate 4
      12-29-2014, 12:17 PM   #2
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Thank you for this DIY!
      02-07-2015, 05:29 PM   #3
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Once again! Thanks for you DIY and you are absolutely right about those retaining clips. It's a pain to remove. Wondering if the dealer sells replacements?
      02-08-2015, 06:19 PM   #4
MasterC17
329
Drives: 2015 BMW M3
Not that I am aware of unfortunately, though it would be nice!
      02-08-2015, 09:30 PM   #5
kautiongsr
bigdaddyjulio
kautiongsr's Avatar
12
Drives: 2011 E92 335IS, 2011 S1000 rr
Nice write up... I just installed carbon steering wheel on my buddy's dinmann M3.
Nice to see both options
Big Daddy Julio
      02-08-2015, 10:21 PM   #6
NorCal f80
346
Drives: M3
I think the trim looks better than the above cf wheel posted. too much cf.
      02-08-2015, 10:40 PM   #7
///M ARMY
1003
Drives: F90
wow looks good.
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      02-18-2015, 10:21 AM   #8
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
Evil is an understatement. Thanks for the DIY. I just went in and manhandled those clips until they popped. Used a regular flat tip to get leverage.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      04-04-2015, 01:29 AM   #9
mdrobc13
mdrobc13's Avatar
341
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Great...thanks
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      04-06-2015, 09:32 PM   #10
///M.Tonee
///M.Tonee's Avatar
311
Drives: Porsche 991.1 GT3
Any instructions how to install the electronic m performance steering wheel?
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee
      04-09-2015, 07:39 PM   #11
IMrMark
IMrMark's Avatar
75
Drives: 2015 BMW M4
2015 BMW M4  [9.66]
Originally Posted by 0-100 ninja real quick View Post
too much cf.
you kiss your mother with that mouth?!
2015 ///M4 F82
[ Mineral Grey | SO Ext | 19" Black | 6MT | CFRP Interior | LED | Executive | Side/Top Cameras | Adaptive M Suspension | HK Surround ]
:: will code locally for rum, beer, or chicken; PM as desired ::
Instagram: IMrMark
      04-22-2015, 11:38 PM   #12
racsos
72
Drives: bmw m3
woooohoooo just installed it!!! Thanks for the diy. Once you finally get the first clip off the rest are definitely easier. You really have to pry those suckers off.
      04-22-2015, 11:52 PM   #13
mdrobc13
mdrobc13's Avatar
341
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Did you re=use them at all? Anyone buy new ones from the factory?
      04-23-2015, 04:07 AM   #14
Longbow64
_______
Longbow64's Avatar
169
Reused all of them. No issue getting them back on. Hard part was getting then off.
      04-23-2015, 08:45 AM   #15
NorCal f80
346
Drives: M3
ew no
      07-07-2015, 05:36 AM   #16
philsM4
Philly50
philsM4's Avatar
Drives: F82 MY16 BMW M4 Alpine White
Wow, that is one sweet aftermarket steering wheel!
      07-07-2015, 09:53 AM   #17
Anchored
64
Drives: E39
I think this mod is a must do.
Really ties the interior together and makes the wheel stand out from the Msport wheel.
      01-29-2016, 04:02 PM   #18
sknobs
sknobs's Avatar
23
Drives: 2016 F82 SO/Extended Black 200
What happened to the pics in the OP?
      01-30-2016, 08:51 AM   #19
MasterC17
329
Drives: 2015 BMW M3
Should be back, Photobucket was doing maintenance.
      11-24-2017, 03:58 PM   #20
jmh600cbr
jmh600cbr's Avatar
271
Drives: G80
2021 BMW G80  [0.00]
photos removed. any help?
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM
      02-10-2020, 02:29 AM   #21
PilotPri
PilotPri's Avatar
15
Drives: 19 M4 & 16 Maserati Ghibli S
I seem to have broke the Retaining clips. Does anyone know where I can find replacement ones ? Dealer needs a part number, and have no idea how to obtain one. Thanks
      05-23-2020, 06:09 PM   #22
Chan
66
Drives: 2015 BMW M4
Thanks for putting this together and good call on using the 5mm socket to hammer those suckers down.
f80post
