12-05-2014, 11:17 PM | #1 |
42
Rep 213
Valve cover leak?
Taking the M3 for its final service under warranty. Saw this wet spot on the front of the cylinder bank. It looks like a valve cover leak to me.
Anyone experience this?
11 Space Grey, M-DCT Base M3
12-06-2014, 07:03 AM | #3 |
63387
Rep 24,678
Yes it's common and always on the same spot ...left side ,under left corner bolt .
How many miles on it ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-06-2014, 07:21 AM | #4 |
Grown Azz Man
429
Rep 3,021
Common issue.....if you're still under warranty it's covered.........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
12-07-2014, 12:17 AM | #5 |
726
Rep 1,974
I've been noticing the same thing and my car only has 20k miles. What's covered under warranty? They clean it up for you?
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
12-07-2014, 06:50 AM | #6 |
192
Rep 3,633
12-07-2014, 07:59 AM | #7 | |
42
Rep 213
I plan on keeping this car for a while. Are these difficult to replace. I've replaced many on e36 models.
12-07-2014, 11:25 AM | #8 | |
63387
Rep 24,678
Personal I would clean it up with a paint brush and some degreaser, and keep an eye on it ! After if leaking gets worse you can try with torque down the bolts . Last step when still leaking is replace the valve cover gaskets by a BMW/Dealer .
12-07-2014, 07:25 PM | #9 | |
42
Rep 213
12-07-2014, 08:12 PM | #10 |
63387
Rep 24,678
Let's hope that they do it under warranty conditions !
12-19-2014, 08:17 PM | #11 | |
42
Rep 213
I took the airbox out before I took it in and swept my fingers under the outside flange of the passenger side and came up wet with oil. SA says that this is normal "misting" from the gaskets. How is BMW going to know if these were not leaking and only misting? Based on mileage? Even if the dealer sent the seals in for a analytical analysis by BMW how could they tell without spending a fortune to analyze them. SA says they will get stuck with the repair.... Maybe I should ask them to replace the plugs while they're in there and then they'll write off the gaskets! I guess I'll be looking for DYI on valve cover gaskets.
12-19-2014, 08:29 PM | #12 |
Grown Azz Man
429
Rep 3,021
You need to find another dealer. If you tell them you've noticed a oil leak and they see the area you have pictured, it's a clear case of a leaking gasket. Mine wasn't as bad as yours and it was done without question. And the SA that told you this is a normal mist should be updating his resume'...........Phil
12-19-2014, 09:13 PM | #13 |
232
Rep 496
12-19-2014, 09:48 PM | #14 |
42
Rep 213
He has worked with me in the past on my 335i and seams pretty reasonable. I'll try the dealer on the other side of town. They did find the tranny leak and are going to fix it.
12-20-2014, 06:53 AM | #15 | |
63387
Rep 24,678
