12-03-2014, 11:45 PM | #1 |
Self Proclaimed Roundel Junkie
630
Rep 1,594
Front End Rattle... Fixed!
I remember reading/discussing this with someone in another thread, but I can't find it now. After some searching, I didn't find a dedicated thread, so I felt it deserved one.
I had a rattle/clunk while driving over small bumps, into and out of driveways/parking lots, etc. Sometimes it was one clunk, other times it was a rattle. Mine seemed to start on the passenger side, but sometimes you couldn't tell for sure. After some searching, I felt that sway bar end links were the most likely culprit (and cheap at only $110 for the pair!). Tonight I swapped them out with a set that I picked up from the dealer. The part number has been changed, so I assume an updated part. Anyway, the fix was quick and easy, and the rattle is GONE! I'm so happy. I've never had such an annoying issue be fixed so inexpensively on a BMW!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
12-04-2014, 12:13 PM | #6 |
630
Rep 1,594
12-04-2014, 07:29 PM | #8 |
85
Rep 479
Is there a way you tested them for play? Like joints you can hold the tire and check for movement.
Is there something I can do to check for play on end links? I'm feeling/hearing alittle jiggle aswel and it's been driving me nuts. |
12-04-2014, 08:26 PM | #9 |
630
Rep 1,594
Not really. Once I had the passenger side lifted and the wheel off, I noticed the top ball joint of the end link felt a little loose. I was tapping them with a dead blow hammer and that one gave a little metallic clunk sound when I hit it. It was very little, not nearly as much as the noise of been hearing had suggested. It gave me hope and after changing it, the noise was gone!
12-04-2014, 08:28 PM | #10 | |
630
Rep 1,594
12-04-2014, 10:16 PM | #11 |
117
Rep 557
Mitch808 - a little OT, but what condo building are you in? I'm in Seattle too, having recently moved from a downtown condo (Meridian on Pike St) to West Seattle. Having a garage is nice, but giving up condo life was an adjustment. Of course, now I don't have to deal with downtown traffic as much either so I don't hate driving as much which is also a plus.
And re: sway bar end links, mine is at the dealer getting this (and a host of other items) done right now. Apparently very common issue. |
12-05-2014, 12:29 PM | #12 | |
630
Rep 1,594
Yeah, it does seem to be common. The fact that the part number changed two times indicates to me that BMW updated and revised the parts, so hopefully I won't have to do it again.
