11-25-2014, 11:18 PM | #1 |
253
Rep 550
Best x pipe
In the service of being able to return the exhaust to fully stock in the future, but being able to eliminate the front cats while having useful secondary high flow cats (200, I think, do they actually remove the smell effectively?) and better performance, what might be the best front X pipe system?
11-26-2014, 06:57 AM | #3 |
5255
Rep 10,628
I think the OP is asking who makes the easiest to install and remove test pipes. There are several test pipes available. They all look the same to me. Maybe one has better clamps than another. Probably having V Bands welded on would be ideal for swapping and leak free sealing, but V Bands reduce clearance by about 1/2 inch so if you are scraping your cats now they may not be a good choice.
11-26-2014, 07:50 AM | #4 |
968
Rep 1,901
Used OEM x pipe and TPs. Then when it's time for emissions swap em out. Keep your X pipe stock. Save lots of $$$
Past: 1999 M3 2003 M5 2006 330i 2007 335i 2009 M3 2013 M3 2018 M3
11-26-2014, 08:48 AM | #5 |
5255
Rep 10,628
Swapping the entire X pipe is more work than swapping test pipes on your existing x-pipe, if swapping test pipes is a viable option. I have removed and installed the stock x-pipe and an aftermarket x-pipe several times. Certainly doable if you prefer to go that way.
11-26-2014, 01:30 PM | #6 | |
BimmerPost Supporting Vendor
2929
Rep 21,738
Normally about a 20 whp gain. You will also need a tune to turn off the CEL if you dont have one already.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-26-2014, 04:39 PM | #8 |
829
Rep 3,387
