11-22-2014, 09:16 PM | #1 |
59
Rep 741
Drives: E87 130i
Oil temp
For those who monitor it, where have you placed your sensor and why?
11-25-2014, 07:05 PM | #2 |
1233
Rep 3,778
Drives: '11 328i '19 M6
There's an adapter that's attached with a banjo bolt to the stock oil pressure switch on the oil filter cover and which provides two ports. With one plugged the other can be used for an oil temp sensor. I think they're 1/8" NPT ports. Bimmerworld makes one and I'm sure there are others, just haven't seen any.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-26-2014, 09:29 AM | #4 |
1233
Rep 3,778
Oil temp sensor? Haven't found it yet, probably not looking in the right place. Gave up and went with separate sensors.
11-26-2014, 09:36 AM | #5 |
827
Rep 3,856
If you get the performance wheel with the electronic readout, I almost positive you can get that to display the oil temp.
11-26-2014, 09:43 AM | #7 | |
198
Rep 2,239
It will.. With coding. The performance wheel with LCD shows oil temp, that's how Stig knows his temps.
08 e93 335i MT
11-26-2014, 10:19 AM | #8 |
1233
Rep 3,778
Oh! Very cool, thanks. Would have to find the information on the PT-CAN bus and use my logger's display to show it. No luck with that so far. Decided to use separate sensors for oil pressure, oil temp, and coolant temp instead to avoid having to sift through bulk CAN data collection.
11-26-2014, 06:16 PM | #9 | ||
Resident Tamed Racing Driver
298
Rep 4,697
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
11-26-2014, 08:42 PM | #11 |
189
Rep 1,026
11-27-2014, 07:11 AM | #13 |
298
Rep 4,697
Correct, as the oil expands as it warms up. My air cooled 911 is the most obvious example of this. When I start the car the oil level gauge is at empty. Once it has been run for 20 minutes it rises right to the middle where it belongs. The 128i is just idiot proofing that process.
11-29-2014, 04:08 PM | #14 |
59
Rep 741
Drives: E87 130i
11-30-2014, 07:11 PM | #15 |
298
Rep 4,697
No coding, the module that comes with the wheel picks up on it.
12-02-2014, 04:37 AM | #16 |
59
Rep 741
Drives: E87 130i
12-02-2014, 06:47 AM | #17 |
298
Rep 4,697
02-06-2016, 08:19 AM | #18 |
139
Rep 439
Bumping this thread with a question - for those who are able to monitor oil temps in the 128, what kind of temps are you seeing (summer, winter, etc)? Similar to the 135? A little cooler I would think...
02-06-2016, 08:26 AM | #19 | |
4338
Rep 6,196
02-06-2016, 05:29 PM | #21 |
139
Rep 439
02-06-2016, 05:43 PM | #22 |
2465
Rep 9,004
Coding I believe, but some say plug and play. My car is a 328i and it has it factory because it's an e92, so you know it will work.
