European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs)
      11-13-2014, 03:06 PM   #1
S801945
Drives: 15 M3
Winter Car Washing
Apologize if this is on the site - couldn't find via search.
Anyone have suggestions for washing the car during the winter? Is the best worst option a touchless car wash and no towel dry?
Thanks
      11-13-2014, 10:54 PM   #2
Wah
IG@i.am.wah
Wah's Avatar
2779
Drives: M2 CS
I just go to those self serve pressure washer places and just accept that in the winter the car won't be perfectly clean.
      11-14-2014, 07:08 AM   #3
Gstone
142
Drives: '18 GT350, '15 M4 sold
wait for 45 degree day and wash it quickly
      11-14-2014, 07:16 PM   #4
rubber_ducky
rubber_ducky's Avatar
386
Drives: roach coach
If you have access to a garage, use ONR.
      11-14-2014, 09:12 PM   #5
Race_Doc11
Race_Doc11's Avatar
460
Drives: 2023 G82 M4
2023 BMW G82 M4  [0.00]
2018 F80 M3  [10.00]
2013 Audi RS5 (Sold)  [10.00]
2008 E93 M3 (Sold)  [10.00]
^^ This
      11-16-2014, 08:53 PM   #6
DETSGTSTARSKY
69
Drives: BMW
I would use a do it yourself car wash with the high pressure nozzle. I bring two five gallon buckets close to full with hot water. I put in my car soap into the buckets after they are filled and put the lids on. I use the first cycle to suds up the water and rinse the car as well as possible just using the rinse setting. I then wash the car with the two buckets using a microfiber mitt. After use another cycle to rinse off the car. I then use a water blade to get off most of the water and work quickly to dry it off with microfiber towels. I will dry the door jambs and trunk area to get any residual water and debris off. I bring my other chemicals if I need to clean the interior with. Then I can throw all the towels and mitts into the now empty buckets to transport home. This works best if you go early morning or late night when you will have more time since I can take an hour or more. Some may say this is too much work but why be lazy on the BMW. In that case just buy a Chevy and never wash the damn thing!
      11-16-2014, 09:06 PM   #7
milpar34
milpar34's Avatar
37
Drives: 2015 F80 M3 (SO/BLK)
Does anyone else have experience with this product, good, bad, or otherwise? Okay known issue with using this in a clear bra?
2019 G07 X7 4.0 - Black Sapphire
2015 F80 M3 - Sakhir Orange / BLK (RETIRED)
2012 E92 M3 - Interlagos Blue / BLK (RETIRED)
2008 E60 528i - Space Grey / BLK (RETIRED)
      11-17-2014, 09:41 AM   #8
Joz132
Drives: 2015 M4
Completely agree - I buy ONR by the gallon.
I use a technique very similar to the "updated" Garry Dean Wash Method.
      11-17-2014, 08:35 PM   #9
milpar34
milpar34's Avatar
37
Why "if you have a garage? " can you not use this product if washing outside our at a car wash self wash bay?
      11-18-2014, 08:59 AM   #10
Joz132
Drives: 2015 M4
It can certainly be used outside, and even in the sun.
I just think garage/winter because of the elements...
It's currently 9 degrees with a windchill of -12 outside (and a balmy 50 in my garage).
      11-18-2014, 11:42 AM   #11
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
I use this on a weekly basis in my condo.
You can certainly use it outside, but the point is to stay warm in the winter so you DON"T HAVE TO go outside. LOL
anyways, I use a liberal amount of this stuff (1.5oz per 2 gallon), just to make sure I don't end up with scratches. There's a WAX and SHINE version, that's the stuff I use. Love it.
I also use the 2 bucket wash method, make sure to rinse the mitt in clean water before dip it back to the soup bucket.
If you wash your car frequently, you should be fine. I have opticoat on my car and this ONR + Opticoat = 20 min wash. wheels = another 20 mins. so you can get everything done in 40 mins.
      11-18-2014, 01:24 PM   #12
milpar34
milpar34's Avatar
37
Thanks M4NACE!
      11-18-2014, 01:43 PM   #13
JoeFromPA
1795
Drives: '15 AW M3 6MT Stripper
My only comment on Optimum No Rinse or similar...
You want to SOAK SALT ENCRUSTED AREAS thoroughly before wiping the crust off. When dealing with that heavily soiled areas, take lots of time, use more water/soap than expected, and do small small sections before rinsing the mitt out.
ONR is an excellent option for winter time cleaning - but you will drag salt across your paint if you aren't very careful.
      11-18-2014, 02:43 PM   #14
ddas
ddas's Avatar
211
Drives: 2018 Daytona Violet M3
An area many don't give consideration is protecting their bodies during the cold weather detailing sessions. For some great tips, read this piece from Detailed Image: http://www.detailedimage.com/Ask-a-P...-on-your-body/
      11-18-2014, 09:29 PM   #15
milpar34
milpar34's Avatar
37
Amazon has ONR Wash & Shine or ONR Wash & Wax. Which one do you recommend?
      11-19-2014, 07:41 AM   #16
rubber_ducky
386
Drives: roach coach
I've only used wash and shine and it works great. If you have the car waxed prior to the winter weather, you can probably skip the waxing product.
      11-19-2014, 07:43 AM   #17
rubber_ducky
386
Drives: roach coach
Joz nailed it. I suppose that it depends on where you live, but a garage can generally normalize the environment to the actual temperature vs the "feels like" temp.
      11-19-2014, 01:33 PM   #18
M3Fanatics
M3Fanatics's Avatar
127
Drives: '15 YMB F80 M3 '15 BSM F15 X5
I was thinking about touch less car wash like 2-3x a week and autoglym aqua wax every 2 weeks, as it gets extremely cold here and would be really difficult to stand outside. What do you guys think?
      11-21-2014, 10:35 AM   #19
Robot2559
Drives: 15 M3
I know it is sacrilegious but I think I'm in the touch less boat too...unfortunately. Just too cold, not realistic. I will not let them towel dry.
      11-21-2014, 11:03 AM   #20
m3incorp
m3incorp's Avatar
Drives: M4 (On Order) 2014 Stingray
Great article.
      11-21-2014, 11:09 AM   #21
m3incorp
m3incorp's Avatar
I was in the touch-less car wash camp for years. This past summer I did a total insulation project on my garage to include putting in a new garage door with the most insulation/UV available. The temps are currently in the mid 20's and the garage during the daytime is tending to be in the mid to upper 40's. A big improvement over what it was last winter. I do have the Race Deck Flooring also and I'm sure that not having to stand on concrete is a help also. This winter I'm hoping to skip the touch less car washes and do more inside.
      11-23-2014, 11:16 AM   #22
cougs99163
cougs99163's Avatar
30
Drives: F80
I have the original and the carnuba variant. Both great and works awesome!
2015 BMW ///M3 6MT: MW, 19" black wheels, extended leather
Mods: IND back grill, 25% 3M Tint, XPEL Ultimate, V1 concealed display setup, Bavsound S1, K&N+charcoal delete
f80post
