11-09-2014, 04:17 PM | #1 |
California-bound
385
Rep 1,480
Inconsistent Pedal
Hey 1Addicts, hoping you could help me do some trouble shooting. A while back, I boiled the brake fluid quite badly at the track, to the point where the pedal did nothing and I had to engine brake off the track, and the brake light came on the dash. I have bled the brakes a handful of times since, but the pedal is still very inconsistent. Sometimes it feels great, then the very next time I go to use the pedal, even seconds later, it feels awful, going to the floor with minimal brake force. The issue persists with different pads, rotors, etc.
I have tested the master, it is holding. None of my brake lines seem to be leaking/the system doesn't show any leaks anywhere. Each bleed of the calipers is showing minimal bubbling, and a firm enough pedal when bleeding. Any ideas on how to proceed? I have been living with the bad pedal for a while now, it is driving me nuts. I have gotten into the habit of pumping the brakes before diving into the pedal stroke, just so I would have brake force. That to me, indicates air in the system, but as previously stated, bleeding the brakes is showing minimal issues with the fluid.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
11-09-2014, 04:33 PM | #2 |
European Editor
10596
Rep 22,992
Check the brake piston seals for leakage. I bet you got the brakes so hot that the brake caliper piston's are leaking. Did you ever change your brake pads after your HPDE ?
11-09-2014, 04:43 PM | #3 |
1Addict
3237
Rep 7,897
What about a brake fluid change at this point?
11-09-2014, 04:44 PM | #4 | |
California-bound
385
Rep 1,480
I was thinking perhaps that air bubbles have lodged themselves in the ABS actuator, since the air bubbles rise, and the actuator is the highest point of the system. However, that's just a guess. I don't tend to ride the ABS much at the track out of habit, so I am not sure how much that could factor in.
11-10-2014, 07:10 AM | #5 |
340
Rep 1,293
I experienced a similar condition when swapping out my calipers to a BBK. I'm pretty sure I ran the resivour dry and had a massive amount of air in the lines. Using a pressure bleeder was worthless. The two person process (with the engine running) helped a lot. A couple weeks later I installed my COBB. During the installation, you can hear just about every electric pump in the car cycle a few times. I can't confirm whether the the the ABS actuator is activated by the COBB, but after the installation my brake pedal pressure was better than new.
Also, if you check the internet, you with find some articles where a guy with an e46 figured out how to pull the ABS relay in the fuse box and jump the contact points to activate the ABS. I'm sure this wouldn't be difficult once you figure out which contact points related to the relay's on/off circuit. |
11-10-2014, 08:31 AM | #6 | |
46
Rep 363
11-10-2014, 03:27 PM | #7 |
California-bound
385
Rep 1,480
I have bled several times since, including again last night! Was able to get some bubbles out, but pedal still feels lackluster. Are the masters/reservoirs really noisy on these cars? I noticed yesterday when I was bleeding, two man style that the master/revervoir was making a suction noise when the pedal was being pushed down. My friend said it sounded normal, but I'm paranoid. I don't recall other cars making noise from the master whwhen bleeding?
11-10-2014, 06:22 PM | #8 |
340
Rep 1,293
Not trying to freak you out, but I don't recall any noise from the MC. That being said, the car was in the garage with the engine running so I couldn't hear much of anything.
