10-21-2014, 02:17 AM | #1 |
39
Rep 257
Issue after Vanos Recall?
Ok, for all of you who have gotten the vanos recall done. Have you noticed any issues? I noticed I have a lot of white smoke coming from the engine bay after it was done. The service adviser did say that the engine may need to burn off a small amount of residue oil after the work was done, but this seems excessive. There are no other issues besides the white smoke. No codes, car pulls fine. Given I've only driven the car 60 miles since the recall was done, but there is a lot of smoke. I'm going to call the BMW shop in the morning to ask em about it. Just checking in if anyone else has had the same thing pop up.
10-21-2014, 05:50 PM | #3 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
It's probably from residual oil as you said (as the valve cover obviously has to come off).
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
10-21-2014, 09:10 PM | #4 |
39
Rep 257
Turns out the valve cover gasket was not installed properly. It was rolled up as they described it. They had to order another one so it'll be in the shop for at least another day.
10-21-2014, 09:23 PM | #5 |
BMW Master Tech
587
Rep 850
Sounds like BS if you ask me. N55/N54 valve cover gaskets are the single most common thing we do. While it is possible that they are out, it's highly unlikely. That being said, it is also very easy to pinch the gasket lol
135is #502 of 586
10-22-2014, 01:21 AM | #7 | |
98
Rep 233
Also the most common valve cover gasket we do would be N52. |
10-22-2014, 08:30 AM | #8 |
670
Rep 987
I think he was saying it's BS they they dont have any on hand
10-28-2014, 12:00 PM | #9 |
BMW Master Tech
587
Rep 850
Correct.
135is #502 of 586
10-28-2014, 07:41 PM | #10 | |
Rep 75
