      10-13-2014, 11:12 PM   #1
Joaco135
Joaco135's Avatar
176
Drives: 2020 M2C LBB
sunroof
Does the sunroof sits flush all the way around when closed? Mine sits a little lower in the back, the front is flush with the roof.
      10-14-2014, 12:50 AM   #2
Huecifer
11
Drives: 128i
Sounds like something is wrong. It should be flush
      10-14-2014, 10:27 AM   #3
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19
      10-14-2014, 11:22 AM   #4
Overpar56
Proud AARP member in good standing
Overpar56's Avatar
28
Drives: Me nuts
Ditto.
No leaks?
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver.
      10-14-2014, 12:53 PM   #5
Joaco135
Joaco135's Avatar
176
No leaks but definitely is not right, ahhh again back to the dealer. My car was probably finish on a Friday before a long weekend or something like that, it has been on the dealer to fix something at least once every 6 months. Might be time to change, oh well.
      10-14-2014, 09:22 PM   #6
Overpar56
Overpar56's Avatar
28
Drives: Me nuts
I have a desk, phone and printer at my dealer. The water cooler conversations are interesting too
      10-14-2014, 09:27 PM   #7
Chunner
Chunner's Avatar
153
Drives: BMW 135is | #341/586
U need to reset the moon roof. Google search resetting BMW 135i moon roof.
      10-14-2014, 10:37 PM   #8
Joaco135
Joaco135's Avatar
176
Well that did it, thanks Chunner. Did a search and this tread came up from e90 post
http://www.e90post.com/forums/showthread.php?t=21785
Post #5 explained the procedure, did it on my car and everything is back to normal.
      10-14-2014, 10:38 PM   #9
Joaco135
Joaco135's Avatar
176
Know exactly what do you mean,
      10-15-2014, 05:29 AM   #10
Chunner
Chunner's Avatar
153
awesome... enjoy!
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler
      10-15-2014, 06:40 AM   #11
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Just for future reference. ALL sunroofs leak. They are designed for it. There is a drip tray around the outer edge that collects the water, and the water then runs down tubes at the four corners which then run underneath the car. You only get water past that if the drain tubes are clogged and don't drain, or there is more water getting past the sunroof than the drains can handle. That usually only happens when you go through a high pressure, touchless carwash.
Check your drain tubes every once in a while and make sure they are clear. I will usually pour a bit of water down the tubes once in a while.
1addicts
