10-08-2014, 07:59 AM | #1 |
Rep 37
Problems after installing Lux H8 V4
I got the Lux H8 v4 angel eyes several days ago and installed them on 2011 X5. Here are a few things I experienced.
1. it flickered when I locked the car which was normal since it didnt have dim function. 2. After I unlock and lock the car 2 times with the remove key, the welcome light will not come up any more. weird? 3. onetime, I unlock and lock several times regardless the welcome light, the remote key stoped working and could not unlock the car. I have to use the key to open the door and start engine. After a minute of running the engine, the key is functional again. weird?? will try again. any comments? thank you all. |
10-08-2014, 08:45 AM | #2 |
11574
Rep 11,136
Your best option is to remove them, ask for a refund, then install some aftermarket halogen bulbs and enjoy having no errors...
But in all honesty: contact Lux directly. Sounds like you installed them correctly, but this is just an issue with your set of LEDs. |
10-10-2014, 10:06 AM | #5 |
Rep 37
10-10-2014, 01:46 PM | #6 |
FDNY Engine 55
681
Rep 2,115
I installed the LUX H8 V4 and I haven't noticed any flickering yet, but they don't light up my outer rings very well. The only flickering I have is my WeissLicht LED fog lights with the error cancelers installed
10-10-2014, 09:27 PM | #8 |
1716
Rep 1,910
Drives: 2023 M5C
10-11-2014, 05:39 AM | #9 |
Rep 65
I think you can code this....
The light is PWM-driven which works with halogens, but apparently not with the LUX. I have the LCI and the coronas turn on "hard". In case anyone with halogen coronas can elaborate: do the coronas brighten up and dim when you lock unlock? If so, you can code this with BMWHat in an easy and affordable way via your iPhone/Android. |
