10-07-2014, 01:14 PM | #1 |
M4-SAHD
512
Rep 611
M4 Service and Open Campaign - Can Terminator (Service Bulletin - SIB)
Hello Thanks to forum member RobRed i was able to get my SIB done in case anyone miss it here
10-07-2014, 05:01 PM | #3 |
INSTAGRAM: @yaasplease
166
Rep 1,023
silent "recall". This is one of them. There are two right now.
EDIT: as pointed out by another forum member. This is not a full on recall. My understanding of a silent recall is one where the customers do not have to be made aware of the situation. The dealership quietly fixes it the next time vehicle is in for service. That usually means the issue is nothing major. I wanted to clarify this point.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out Last edited by redfox; 10-07-2014 at 05:25 PM.. |
10-07-2014, 05:03 PM | #4 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
It is not a recall. It is a service bulletin. There is a big difference.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
10-07-2014, 05:26 PM | #7 |
166
Rep 1,023
Water drainage - apparently applying sealant to an area that could leak.
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
10-07-2014, 06:32 PM | #8 |
2939
Rep 4,087
10-07-2014, 07:38 PM | #11 |
M4-SAHD
512
Rep 611
10-07-2014, 08:31 PM | #12 |
73
Rep 240
CAN bus, or Controller area network. It's a protocol used mainly in the automotive industry and audio. It's used for control boards and systems to communicate. It's a linear bus topology and needs to be terminated to work correctly. Lack of proper terminal in a linear bus can lead to all sorts of errors. But, I'm sure there are more then one CAN bus within M4, and I'm sure it's not a critical one, however, all CAN buses need to be properly terminated.
Not a bad write up on CAN bus protocol for those interested. http://en.wikipedia.org/wiki/CAN_bus Since it says retrofit resister, that means either the value is off a bit leading to internal reflections on the bus, or the value of the resister isn't up to spec in tolerance maybe a 5% resister was used instead of 1% or, maybe the resistor wasn't automotive grade quality. Most circuitry in an automobile has a tolerance of -40C to 250C. My gut tells me it's along those lines hence the retro fit. But being a BMW, this resister isn't a simple ceramic, it's most likely SMD (surface mount and you can't be just replaced) hence in reality, they'll yank the board that part of the termination and replace it (probably a 100.00 board for a .5 cent resister). Now some CAN buses are terminated with a simple RJ45 terminated internally and used for this purpose, really depends on how it's done. I have my money on a simple little board swap (BMW isn't going to use RJ45 connectors for CAN bus termination - that's for little shops with no money) Last edited by huatian; 10-07-2014 at 08:53 PM.. |
10-07-2014, 08:45 PM | #13 | |
Rep 32
I hope this is a coincidence but thought I'd share my experience. |
10-07-2014, 08:51 PM | #14 | |
73
Rep 240
10-07-2014, 09:40 PM | #15 |
21117
Rep 20,741
Drives: 2021 911 turbo
10-11-2014, 04:21 PM | #16 |
29
Rep 121
Just went in for my break-in service and had the CAN terminator show up as a bulletin. They didn't have the part so they have to bring me back in. Might want to call to make sure they have the part if you're bringing it in for service and want to get everything in one go.
2015 F82 M4 DCT (current) / 2012 991 C2S PDK / 2011 E92 M3 6MT / 2009 Cayman 6MT / 2007 E92 335i 6MT / 2004 E46 325xi 6MT / 2000 E36 Z3 M Coupe 5MT |
10-13-2014, 04:23 AM | #17 | |
66
Rep 204
11-27-2014, 06:14 AM | #18 | ||
M4-SAHD
512
Rep 611
02-06-2015, 10:37 AM | #19 |
67
Rep 183
i just returned from the dealer after having a 6mos check up completed. my m4 is subjected to this open campaign and will have the part replaced when it comes in. i was surprised really as the car runs beautifully and would not have known there was any issue whatsoever.
