10-03-2014, 02:28 PM | #1 |
23
Rep 179
What line is this?
Okay so my car has been idling rough lately, I just found a leak where I least expected. Just wondering what the line exactly is and where it comes/goes to. Its NOT the red arrow but the YELLOW one. Thanks guys!
__________________________________________________ ____________________
09' Crimson Red 135i - FBO, E50, PTF tune, cool stickers |
10-03-2014, 02:29 PM | #2 |
137
Rep 952
Plastic pipe is vacuum for the brake booster. Small rubber hose is supply for exhaust flap.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
10-03-2014, 02:45 PM | #3 |
23
Rep 179
awesome thanks a lot man! not the cause of my rough idle then, but hey a leak is always bad haha.
10-03-2014, 04:13 PM | #4 |
12
Rep 324
A significant vac leak will make for a rough idle
LSXOCET - 404rwhp @ 1600 lbs curb weight... bonkers fast
10-03-2014, 04:42 PM | #5 |
European Editor
10591
Rep 22,992
+1.
Even a leaking valve cover gasket or loose oil cap - can cause a vacuum leak/rough idle. That's why those small parts are also covered under the federal emissions warranty. It's more likely a rough idle is caused byin this order...) worn spark plugs, bad coil(s), dirty injectors, and or carbon buildup on the intake valves. Dack
10-03-2014, 05:36 PM | #6 |
23
Rep 179
Thanks a lot guys! Sadly it did not fix my rough idle, but glad I got it fixed regardless. Have new injectors and plugs. If anything I know its due to the fuel pump, been pulling the fuel pump plausibility code for a few months now. Also it has 43k miles with no valve cleaning done yet. Still under warranty though so trying to get both covered but the dealership isn't budging. Maybe towards the end of my warranty next year they will just do it.
