      10-02-2014, 11:38 AM   #1
Teqnik
Drives: 2009 BMW 135i
135i Car Jack
Hello,
I was wondering if anyone had a recommendation for a low profile car jack for a stock 135i. Just looking to use it for oil changes and basic maintenance. I've tried rhino ramps but they slid around too much for my liking.
Thanks.
      10-02-2014, 11:50 AM   #2
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
1.5 ton low-profile jacks from harbor freight.
      10-02-2014, 12:04 PM   #3
JimD
JimD's Avatar
368
Drives: 128i convertible
I use a Harbor Freight, I think it is 3 ton, that isn't low profile. I roll the bimmer up on 1.5 inch thick ramps I cut from a scrap 2x4 so I can get the jack under it. I lift on the center front for an oil change and lower the car on jackstands on the sides.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      10-02-2014, 01:27 PM   #4
Dilmorecg
Dilmorecg's Avatar
115
Drives: 2014 X5 50i
Thats the one I have too...I still have to drive up on a 2x4 on the front wheels to get it under the front though.
      10-02-2014, 01:42 PM   #5
Kgolf31
Kgolf31's Avatar
460
Really?
I can get under mine no problem @ this ride height:
      10-02-2014, 01:45 PM   #6
Teqnik
Really?
Would you be able to link the one you have specially?
Also, do you require an adapter or anything between the jack and the car itself?
      10-02-2014, 02:04 PM   #7
Kgolf31
Kgolf31's Avatar
460
http://www.harborfreight.com/rapid-p...html-7814.html
Be on the look out for coupons. Typically you can get the jack for much cheaper than what the website says. Just FYI.
No, I just use the jack directly on the jackpad.
We warned, you probably won't have the travel to jack the car all the way up to get it on 4 jack stands, it doesn't have enough travel in my experiences.
I use a 2 ton for that:
http://www.harborfreight.com/2-ton-l...ump-60678.html
      10-02-2014, 04:05 PM   #8
Teqnik
Thanks a lot.
Which one would you recommend for oil changes?
      10-02-2014, 04:20 PM   #9
edisapimp
Civil Rights Activist
115
Drives: E46 Sedan, E88 Vert
Am I the only one who read "135i car jack" and thought this was going to be a thread about being held up at gunpoint by a car thief?
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame.
BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets
      10-02-2014, 04:44 PM   #10
mahlerbeatdown
39
Drives: '09 128i
Thanks a lot.
I bought the following:
http://m.harborfreight.com/2-ton-low...not%20provided
Its long enough to reach the front jack pad no problem.... The cheaper ones are shorter and you'll need your front on ramps or 2x4s for clearance.
      10-02-2014, 06:16 PM   #11
lastMleft
lastMleft's Avatar
30
Drives: e92 M3
That would be car jacked not jack...lol....
      10-02-2014, 06:32 PM   #12
Teqnik
still hilarious lol. sorry i should've titled it a little better. thanks for the input everyone!
      10-02-2014, 06:49 PM   #13
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
I use the arcan low profile jack from Costco. Reminds me, I need to oil that sucker.
Cheap, strong, good travel (jack stand compatible), easy to use.
Only down side is that it weighs almost 110 pounds. Not a big deal.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      10-03-2014, 07:01 PM   #14
patricksr
Drives: BMW M2 Comp
I use Race Ramps and have had no trouble with sliding and a stock 135is has no trouble going up the ramps.
      10-03-2014, 07:20 PM   #15
Overpar56
Proud AARP member in good standing
Overpar56's Avatar
28
Drives: Me nuts
Harbor Freight jacks are crap. I had one that had fast lift and once I had the car up on jack stands, I couldn't get the car off them since the HF POS failed to raise. Viagra couldn't get it up. It leaked fluid all over the place. I had to go to Sears Hardware to get a new jack. The HF POS was only 2 years old.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver.
      10-03-2014, 08:08 PM   #16
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I use the same jack and it's been solid for the last 4 yrs. If I want to jack up the entire front end, I jack up each side and put two bricks next to each other and a square 8 x8 piece of 3/4 inch plywood on top of the bricks, under the front tires. That's just high enough for my jack to reach the center jack point. Keep in mind I am on swift springs.
      10-04-2014, 07:02 PM   #17
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Since I removed my undertray I just push up on the bottom of the bumper and slide the jack in there. I'm on swifts as well. I will say I couldn't do that if I was still running my undertray.
      10-05-2014, 09:39 AM   #18
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Good to know. Just curious, why did you remove the under tray? What about the other pieces, like the wheel wells, transmission cover, don't they just flop around?
1addicts
