09-23-2014, 11:53 AM | #1 |
41
Rep 267
e92 m3 front windshield top rubber molding
so go figure my 08 m3 has its top rubber molding cracking and falling apart. I've searched here and seen that a one piece can be bought and slides right in. it's only the top sections not the full 3 piece kit. has anyone had experience with this or do people remove the glass and buy a whole section molding. thanks.
09-23-2014, 12:06 PM | #2 |
41
Rep 267
I saw that the top rubber molding is available for the e90 m3 platform. are the coupes just not the same or can the e90 moldings be used as well on the coupes. thanks guys
http://www.e90post.com/forums/showthread.php?t=573281 |
DrFerry6728.50 |
09-23-2014, 01:51 PM | #3 |
13
Rep 259
here is the link for the part for a coupe
http://www.getbmwparts.com/parts/200...agramCallOut=2 BODY HARDWARE / WINDSHIELD / GLASS / Reveal molding Part Number: 51317119711 reveal molding COUPE MSRP Core ? Save Online Price $33.78 $0.00 $6.76 $27.02 |
09-23-2014, 03:38 PM | #4 | |
41
Rep 267
09-23-2014, 04:44 PM | #5 |
41
Rep 267
If you notice that's the sides and top al together. The e90 is separated. The top is a different piece. I'm assuming the coupes its a full assembly? And the sedans have a separate top rubber molding.
09-23-2014, 08:47 PM | #7 | |
41
Rep 267
09-29-2014, 02:25 AM | #8 |
No 55mph
1622
Rep 8,476
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-07-2014, 01:30 AM | #9 |
Rep 5
I can confirm that you don't need to remove the windshield. I just replaced my window glazing on my E92 M3. It was quite simple, just used a non-maring tool to press in the sides and the top portion I just pushed in by hand.
The only thing I would caution on is make sure you clean the areas next to the windshield really well and scrape the glass of all the left over residue from the old moulding. Also be very careful not to put sudden pressure or strike the corners/edges if the windshield, it can cause a crack. |
DrFerry6728.50 |
