09-17-2014, 05:41 AM | #1 |
16
Rep 53
Crackle and pops - JB4 vs PPK1
I was wondering if PPK crackle and pops can be obtained with JB4 as well. Apart of the big $$ difference, I'm not sure I want the loudness ALL the time (may change opinion after the fact) so it would be nice if it were "optional" depending on map used.
Thoughts? |
09-17-2014, 06:49 AM | #2 |
European Editor
10591
Rep 22,992
Noop.
09-17-2014, 07:35 AM | #4 |
137
Rep 952
Yep the software in the DME is different, causing the pops and crackles on overrun. JB4 is just a piggyback so it doesn't really alter the DME software at all... Just "tricks" it. And on my car, the pops and stuff only happen when I have the sport button pressed, and trans in sport mode.. So it's optional. Not sure on 6MT cars.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
09-17-2014, 07:57 AM | #5 |
21
Rep 157
Mine has crackles and pops on deceleration in gear with just JB4 and an axleback. Can't say I've heard a car with PPK1 in real life though so I'm not sure what the difference would be.
09-17-2014, 07:43 PM | #6 |
126
Rep 3,099
it all depends how it's tuned
more fuel = more unburnt fuel = more pops and crackles. so yeah JB4 should give some, even more with a back-end flash for more timing etc. |
09-18-2014, 07:57 AM | #7 |
188
Rep 2,226
My JB4 on an otherwise stock car did a hell of a lot of crackling.
I'd wager the JB4 can give you MORE crackles and pops than the PPK, simply because the JB4 can be used to keep the exhaust flap open the whole time. |
09-18-2014, 11:54 PM | #8 |
Rep 29
So are there any off the shelf flashes available that don't cost lots of $ that give all kinds of burble action like the PPK? Does the BMS backend flash do this?
09-19-2014, 07:24 AM | #9 | |
188
Rep 2,226
I'd imagine the cobb tunes will too, but I have no experience with them. |
09-19-2014, 10:49 PM | #10 |
Rep 29
I've got a JB4 but it doesn't make anywhere near the same amount of burble that I've heard in videos of PPK with stock exhaust. I've got golf tee/canflap. I think I read that JB4 can't adjust the fuel / timing appropriately to do it
09-19-2014, 11:02 PM | #11 |
63
Rep 901
Go into debug mode and change Speedometer option 10 from Tach 80 to Tach 0.
Wastegate position at 0 will give you the rumble and pops that you might be looking for. Good luck!
2011 VO 1M
09-22-2014, 08:53 AM | #13 | |
97
Rep 939
09-22-2014, 10:43 AM | #14 |
188
Rep 2,226
09-23-2014, 07:29 AM | #16 |
188
Rep 2,226
09-24-2014, 05:33 PM | #17 |
63
Rep 901
No, it will be less because the wastegate will be fully open during idle and light acceleration instead of partially closed. Metal(lic) noise should actually be covered up if you have any preexisting rattle. Of course it all depends on how bad you have it IF you have any rattle prior to making adjustments.
2011 VO 1M
09-25-2014, 02:10 AM | #18 |
Rep 29
If I understand correctly, this should yield the same sound at light throttle positions as map 8 (reduced power mode)? I often drive around in map 8 just for the sound lol
09-25-2014, 07:25 AM | #19 |
129
Rep 917
A lot of these people don't know what they're talking about. In their defense they are surmising due to what makes sense but these cars don't really make much sense. lol. The DME software is the only way to increase the pops and burbles. A JB4 isn't going to make a difference. I'd like to see a video of someone with a JB4 set on map 0 make less pops than the same car on any other map. I had the pops on the initial software revision for my 2011. After an update to the DME they were nearly gone. My friend with the same year car with PPK sounds completely different. That thing pops and bangs like crazy. I have 20 pounds of boost with the JB4, he has 11 with the PPK.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
09-25-2014, 11:04 AM | #21 | |
137
Rep 952
09-25-2014, 11:44 AM | #22 |
456
Rep 6,478
If you really wanted to, i'm sure you could get the JB to batch fire it rich post-shift for that "bang" everyone likes, or throw a bunch of fuel at it when you get off load.
It's really not that complicated...
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
