09-06-2014, 10:18 AM | #1 |
108
Rep 1,042
Combox retrofit help! USB Audio
Hey guys..
hopefully there is a guru out there that can help. I just did combox retrofit. everything works but USB audio. I can connect my iPhone 5 to USB and it works, but when i plug in a normal USB stick w MP3s it stays greyed out. Any thoughts? Im using the same USB stick that i did with my 6FL/MULF2 previously that worked fine.
09-14-2014, 04:50 AM | #2 |
274
Rep 2,664
Drives: Goggomobil
If you plug it into the one in the glovebox it will not work. That's only for back up. Use the same port as your iPhone. Otherwise unsure as to what the cause may be.
F86 X6///
