Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      09-04-2014, 09:31 PM   #1
parky1215
parky1215's Avatar
564
Drives: F90 M5C | G06 X6 M60i
DIY *Interior Rattle Fix*
I noticed that my brand new M3 makes quite bit of noise inside the car.
Coming from e92 335is, this was quite unexpected as my previous car was very quiet inside.
Tools Needed
1mm Felt Tape <- Click link to purchase from Amazon
Gummi Pflege
Scissors
1 - Rear Audio Speaker Area
There was pretty bad plastic rattle noise coming from rear area.
After taking a look at the area, I noticed there are these plastic covers (total of 3 in M3) behind the rear seat where rear speakers are located.
Just tap the surrounding area with your finger while these covers are in closed position.
If you do hear some plastic rattle noise, then this simple fix will resolve your issue.
Just apply 1mm felt tape under the cover so that the plastic cover and bottom piece do not come in contact directly. Do the same thing to other two covers.
2 - Front A/C Trim
Roman@ESS posted great tips on how to fix some noises coming from front A/C area.
I followed his tips and added some twists to fix noise from AC trim.
1. Pull out A/C CF trim
This piece comes out easily without using any pry bar.
Just follow first 25 seconds from this video to take out the trim.
Make sure your car is off before pulling this out as you have to disconnect 2 connectors.
2. Pull out AC vent from CF trim
This piece is actually quite hard to take out.
Contact points that are holding AC vent is somewhat fragile and can break if you apply too much force.
If you are not confident in your skill, you can skip this and go to step 4.
3. Apply felt tape around AC vent area
Once you take AC vent off, it will look like picture* below (sans green tape).
*This picture is borrowed from Roman@ESS.
Apply felt tape around the area that is marked red. This is area where AC vent makes contact with CF trim area.
It is not necessary to show felt strips on the outside area like shown below. If you want, you can cut the tape so that it only covers inner area where AC vent piece meets the CF trim area.
4. Secure two connector housings
I also noticed that two places that connectors go in can move a lot and make some rattle noise.
I applied felt tape around these so that they cannot move.
5. Apply Gummi Pflege to AC vent contact points
Gummi Pflege works great to get rid of creaking noise coming from the trim.
<Updated on Feb 7, 2015>
You can also use synthetic grease from Super Lube or any similar product. I think this product will last longer than gummi.
http://www.amazon.com/gp/product/B000XBH9HI/
Apply Gummi Pflege to area highlighted in red below.
Wipe excess Gummi Pflege using microfiber.
Put the entire trim back after letting it dry for 10 minutes.
Test both door lock/unlock and emergency signal light buttons.
Tip: When you put the trim back, it may not want to snap in to place.
If you are having this problem, you may have cables stuck between ac vent and duck. Position both cables so that they do not get in the way.
I taped both cables with electrical tape so that it is easier to position them when putting the trim piece back.
3 - Dome Light Unit
There is piece of plastic covering dome light area.
Lightly pull down plastic cover using your fingers (red arrows indicate points where you need to pull down).
Remove entire dome light unit that is held by 2 retaining clips.
Working one side at a time, insert pry bar into the gap and push the clip to the direction of the red arrow.
While holding the pushed clip, use another pry bar to slowly pull down the unit.
There is white plastic plastic piece that goes across left/right side of the hole. It is attached to metal frame by 2 plastic screws.
I noticed that there were some gap in the middle section (between 2 plastic screws) causing it to rattle against metal frame. You can test it by lightly tapping that section upward.
Good fix would be to take those plastic screws off then apply some felt tapes between metal frame and plastic. However, I couldn't figure out how to take those screws off.
Instead, I just insert felt tape (marked in red in picture) to eliminate the noise. I had to stack 4x 1mm felt tape to fill the gap between these 2 parts.
Install everything back.
4 - Door Seal
I was also getting some noise from door/roof area.
After searching for this issue on Google, I found out that similar problem appeared on previous generations of BMWs.
When you open the door, you will find 2 door seals.
Apply Gummi Pflege on the door seal 1.
There is no need to apply Gummi on door seal 2.
Do the same things to passenger door seal(s).
Let it dry for approximately 10-15 minutes before closing the door.
Re-apply Gummi Pflege to same area whenever the noise comes back.
5 - Rear Center Console Trim
Pull rear center console trim using pry bar.
It comes out fairly easily.
There is cable connected to this trim.
You do not have to disconnect the cable.
Just pull the trim out slight and leave it there.
There are 3 plastic pieces that sticks out (one at top and two at bottom).
These pieces will hit and rattle against the plastic pieces on the other side.
Wrap felt tape to these plastic pieces that stick out.
Do the same thing to right side.
Install rear trim back by pushing it in.
Door panel rattle fix tip from Oakleyguy
Originally Posted by Oakleyguy View Post
Disassembled my door panels, applied Pfledge to many many surfaces and it appears my door creaks are now gone.
Pfeldge in circles, also pfledge around edge of door panel as it connects to the door frame. Not pictured, but I Pfeldged the foam near the tweeter and most of the plastic retaining clips for the wiring. Basically Pfledge every connection point the panel has.
Warning: Not for novices. If you aren't careful you will mar up your leather and the door handle cover can be quite tricky to remove. Proceed at your own risk.
Image crop, but continue to apply Pfledge to remaining "holes"
Video showing how to remove door panel
Additional tips from dd1981
Originally Posted by dd1981 View Post
Good thread you put together I love it.
Try this one too for all the HUD optioned cars. This was by far my most annoying creak I ever had!
http://f30.bimmerpost.com/forums/sho...ght=Rattle+fix
I don't have an F80 but I live in the F30/32 community and have been battling these type of issues since I've brough my 335 home should be all 95% similar with the interior stuff. I also have put together a few fixes, much of the same ones you have encountered.
I also had this close out panel float around and make noises...
This is the passenger side kick panel I had issues with..
http://f30.bimmerpost.com/forums/sho...d.php?t=767929
Hopefully you M3/4 guys don't have all these issues, but I figure share my F30 experiences to save some headaches. Cheers.
Enjoy significantly quieter interior
Appreciate 29
      09-08-2014, 01:17 PM   #2
Oakleyguy
Resident Engineer
Oakleyguy's Avatar
135
Drives: Land Cruiser
2014 Toyota URJ200  [0.00]
2017 BMW M2  [0.00]
2015 BMW M4  [10.00]
2005 Toyota UZJ100  [0.00]
Thumbs up
BOOKMARKED. Good work!
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD
2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air
European Delivery Journal & F8X Door Rattle Fix
Machine Shop Directory - www.mfgcenter.com
      09-08-2014, 03:14 PM   #3
IMrMark
IMrMark's Avatar
75
Drives: 2015 BMW M4
2015 BMW M4  [9.66]
oh yeah, I have a feeling this will come in handy later on
2015 ///M4 F82
[ Mineral Grey | SO Ext | 19" Black | 6MT | CFRP Interior | LED | Executive | Side/Top Cameras | Adaptive M Suspension | HK Surround ]
:: will code locally for rum, beer, or chicken; PM as desired ::
Instagram: IMrMark
      09-08-2014, 03:40 PM   #4
Keto
Keto's Avatar
73
Drives: F80 M3
2015 BMW M3  [10.00]
I know shitty New Orleans roads will make this thread a necessity later. Awesome job!
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed
Bavsound Stage 1 : V1 Savvy hardwired : Self-coded
      09-08-2014, 06:12 PM   #5
mpbruin108
Mpbruin108
mpbruin108's Avatar
187
Drives: I'm a hypermiler
I wonder if the M4 has these rattles too. I guess I'll bookmark this and see if it does when I get the car.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539
Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s
      09-08-2014, 08:45 PM   #6
parky1215
parky1215's Avatar
564
I added additional steps to dome unit area to address rattle issue between dome light unit and its holder. With this, I am pretty much rattle free in most road situation.
      09-09-2014, 07:30 AM   #7
rubber_ducky
rubber_ducky's Avatar
386
Drives: roach coach
Very nice work. Thanks for posting.
      09-14-2014, 03:16 PM   #8
mic_crispy
225
Drives: 2002 | 964 | x1 M35
Hopefully this will reduce some of the creaking around the front vents / HU.
2020 M2C.
      09-14-2014, 05:55 PM   #9
drjochen
Drives: 2011 M3 sedan
Great post. Kinda sad that this needs to be done to a $70,000 car......
      09-15-2014, 09:51 AM   #10
RocketBoots
RocketBoots's Avatar
1860
Drives: Horse Drawn Carriage
Thank you for posting this!
      09-17-2014, 08:09 AM   #11
hadoken
Drives: F30 335i xDrive, F82 M4
Thanks for the write up. I am getting a terrible rattle/creaking from the center A/C trim. Going to try it this weekend.
2015 F82 M4
2014 F30 335i xDrive
2012 Tundra 5.7L
2004 S2000
      09-17-2014, 01:41 PM   #12
///M ARMY
1003
Drives: F90
Tools Needed
1mm Felt Tape
Gummi Pflege
Scissors
2 - Front A/C Trim
3 - Dome Light Unit
Apply felt tapes.
Once it’s out, you will see CF roof (if you have CF roof).
Area that rattles against dome light unit is highlighted in red.
Apply felt tape directly to black dome light unit to the area that comes in contact with highlighted area below.
4 - Door Seal
I do have rattling from all over. I am going to try Gummi Pflege on the door seals and see whats happens .
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      09-19-2014, 08:42 PM   #13
CatchM3
CatchM3's Avatar
259
Drives: 2020 X6M Competition DG
2008 E90 M3  [9.00]
awesome write up! thanks!
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
      09-20-2014, 10:51 AM   #14
mic_crispy
225
I had the creeks etc from the vents. The totally fixed it.
      09-22-2014, 01:31 PM   #15
Benfmd
15
Drives: 2015 Mineral White/SO M3
Rattle/crackling noise in M3
Just picked up my new mineral white/SO M3 last week. I notice that when going slowly up a hill or on slow turns there is a rattle or crackling like noise coming from both sides of the car. I think possible from the doors or seats. It sounds almost like the creeking sound you might hear on a ship.
I do not hear any rattles or like sounds when going over bumps or at faster speeds.
Anyone else experience this? What can be done about it?
Thanks
My BMW history: 1977 320i, 1993 325is, 1995 E36 M3, 1999 740i Sport, 2004 E46 M3, 2005 E46 M3 ZCP,
2008 E60 M5, 2011 E93 M3 convertible, 2011 335 Xdrive, 2008 X5 3.0 (current), 2015 M3 Mineral White/Sakhir Orange (current).
      09-22-2014, 01:34 PM   #16
phil.harlow
Driving Enthusiast
phil.harlow's Avatar
152
Drives: 2021 F90 Comp Frozen Bluestone
2018 BMW M3  [0.00]
My girlfriend's F30 creaked like crazy when going over uneven ground where the body flexes. The fix (found on the forums) seemed to be lubing the seal between the windows and the rubber gaskets. We had the dealer do it, and the creaks reduced about 90%, but they are slowly coming back again. I'm sure others will have more helpful tips, but I'd guess it's the window seals.
2021 Frozen Bluestone ///M5 Comp - Ordered 9/6/20 | Finished Production 10/19/20 | Delivered 12/13/20
2018 Mineral Grey ///M3 - Ordered 7/24/17 | Euro Delivery 9/1/17 | US Delivery 10/31/17
2015 Mineral White ///M3 - Ordered 4/6/14 | Finished Production 8/28/14 | Delivered 10/11/14
2011 Black E90 335xi - Ordered 7/10/11 | Finished Production 7/20/11 | Delivered 9/3/11
      09-22-2014, 01:38 PM   #17
///M ARMY
1003
Drives: F90
Yes I have the same issues after applying some sealant and still have the issue.
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      09-22-2014, 02:19 PM   #18
Benfmd
15
Just saw the other longer thread on this issue. I feel better knowing that this problem is ubiquitous among M3/M4 owners. I will have the dealer address it at the 1200 mile service. The strange thing is that as creaky/rattly the car is at slow speeds on the street, it is rock solid at high speeds even over bumps. No creeking or rattles at all.
      09-22-2014, 04:05 PM   #19
ISM4
Drives: Bmw M4
I'm pretty sure their might be a recall on the f8x for door trim. Check with your dealer. Heard this source from a service advisor.
      09-22-2014, 05:08 PM   #20
RussDC
13
Drives: 2015 M3
Same here man. Drives me crazy!!
      09-22-2014, 05:51 PM   #21
drjochen
Gummipflege. Fixed it for my E90 M3 once and forever.
      09-22-2014, 08:43 PM   #22
Benfmd
15
If I roll down all four windows about 1 inch about 90% of the creaking goes away. The dealer should be able to fix this.
f80post
