09-04-2014, 08:00 PM | #1 |
292
Rep 1,473
Best way to launch DCT at Drag Strip
I have an FBO Z4 35i running E50 with DCT and I am planning on hitting the drag strip in 2 weeks. This car is so much easier to get our of first gear without spinning everywhere than my previous 135i 6MT but I want to get some ideas on how to run the fastest time. I have heard that it is best to launch in 2nd gear and I have also heard to launch from 1st in sport plus mode and manually shift into 2nd and so on. I could also use launch control but it seems like this will cause significant spinning to get out of 1st.
This is the first time to the drag strip with this car and I want to run the fastest launch rather than experimenting all night. What are you thoughts. |
09-04-2014, 10:29 PM | #2 |
121
Rep 653
From my experience it's a tricky situation LOL! What I have the best luck with is launch mode 3500rpms take foot completely off the gas till rpms drop to around 2200-2500 take left foot off of brake press accelerator about 15% AFTER left foot has been taken off the brake. Usually results in a hard no spin launch. I have my boost limited at 12 in first and 17 in second. I short shift into second at 5500 bc it cuts power If I go any higher
2012 DCT 135i
PURE S2 JB4/mhd Fuel-It! direct port meth injection check out my youtube channel here Last edited by Newguy123; 09-05-2014 at 05:40 PM.. |
09-05-2014, 05:15 PM | #3 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Why don't you use launch control?
09-06-2014, 03:04 AM | #4 |
Topless Speed
19
Rep 158
You mean that BMW thought ahead for just this situation and provided a built in system to help you launch the car when you wanted to race? wow... they are good guys...
2013 135i M Sport Convertible JB4, DP, FMIC, BMS Meth & E85. Quafle LSD 3.46 |
09-06-2014, 05:35 AM | #5 |
46
Rep 124
I couldn't do better than a 2.2 60ft until I read this thread. http://www.1addicts.com/forums/showthread.php?t=651971
It works amazingly well. I pulled a 1.8 sec 60ft on all seasons by using it. |
09-06-2014, 11:49 AM | #6 | |
121
Rep 653
09-07-2014, 07:46 AM | #7 | |
11
Rep 30
09-07-2014, 01:13 PM | #8 |
121
Rep 653
I tried the tap tap tap technique and it works fairly well. Launching at 2600ish (on the accel) of the pedal not decel was a very hard sticky launch! If you launch in the decel it's no bueno
2012 DCT 135i
PURE S2 JB4/mhd Fuel-It! direct port meth injection check out my youtube channel here |
09-07-2014, 01:16 PM | #9 |
46
Rep 124
Yeah, I don't know why it works. It feels like a glitch in the system, but it definitely does the job. I do not use this on a regular basis at all though.
09-08-2014, 09:11 AM | #11 |
2286
Rep 12,565
I just think he's saying that you can't launch when the RPM's are dropping during brake boosting. You need to keep tapping or feathering the throttle?
09-08-2014, 10:47 AM | #12 |
46
Rep 124
09-08-2014, 11:05 AM | #13 |
121
Rep 653
YeAh if you look above at the link jake1220 posted it explains the tap tap tap technique. Launch works good if you release the break as your lightly pressing the gas
09-08-2014, 12:11 PM | #15 |
121
Rep 653
tap the throttle to the floor while completely holding the brake down. make sure everything is turned off, you're in sport mode click left padlle to ensure in manual sport mode then tapthe gas pedal to the floor and release multiple times watch your rpms start to rise then you can launch
2012 DCT 135i
09-08-2014, 12:20 PM | #16 | |
11
Rep 30
09-08-2014, 12:37 PM | #17 |
828
Rep 2,232
I must have the older software still. 10/10 Build of MY 2011. I have the circle with the exclamation point when everything is fully off and if I recall correctly the newer one has the car going sideways symbol for fully off? Or did they go back to the circle for fully off now? Anyways, this isn't working for me. Any thoughts on getting the upgraded software from the dealer? How do you even go about asking for that?
09-08-2014, 08:09 PM | #18 |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
