      08-23-2014, 09:00 PM   #1
pick333
42
Drives: 2013 BMW series 1 135i
engine/oil temperature
Is an engine/oil temperature of 248 degrees about normal?
      08-23-2014, 09:18 PM   #2
cbl117
cbl117's Avatar
99
Drives: 2013 e92 335i
Do you have an oil cooler?
If yes, its a tad on the high side unless sitting in traffic in summer heat.
      08-23-2014, 09:39 PM   #3
m981addicts
m981addicts's Avatar
145
Drives: 98Mz3-09-135i6sp-13-135isDCT
Is the needle pointing almost straight down? If so, that's normal for me...75 - 80 mph to and from work. I start at a distance @home/work just far enough from the on ramp to have the motor oil warmed up almost to operating temp a few minutes after I'm in the fast lane.
      08-24-2014, 06:02 AM   #4
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
With OEM oil cooler, I get oil temps of 130*C/266*F when I track my car.
When I come back into the pits, I never turn my N55 engine off and put the heater on with the side vents blowing hot air out of the window until oil temps of 110*C/230*F .
Usually take about 3-5 minutes of running at idle, with heater on and hood opened.
The N54 and N55 turbo engines get extremely hot when pushed.
With that said, my N55 engine never got into the limp mode at the track, even on hot days.
My engine oil breaks down and shears after about 8-10 track days. How I can tell that my oil is toast is that my N55 engine will start to consume oil. This happens after about 8-10 track days (digital gauge shows fractions of a quart/liter below full). Not a drop of oil is consumed before that point (digital gauge always shows full).
So my cue is when my N55 starts to consume oil - at this oil breakdown stage, the used 0W40 Castrol "European Formula" oil comes out "water" thin.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      08-24-2014, 11:15 AM   #5
awns729
33
Drives: 2008 BMW 135i Convertible
N54. Yes that's about normal. I vary between 235-250. Usually 240-250. With OEM oil cooler. Edit: Not sure if your N55 is different.
      08-24-2014, 11:46 AM   #6
Teqnik
Drives: 2009 BMW 135i
I have an N54 and run about 240 on average.
On a side note, does having an aftermarket cooler help with a daily driven car that isn't tracked? I change my oil every 6000 miles or so. Thanks.
      08-24-2014, 05:30 PM   #7
dcaron9999
dcaron9999's Avatar
157
With OEM oil cooler, and Cobb Stage 1 Agressive Tune, I get oil temps of up to 130*C/266*F when I track my car.
      08-24-2014, 07:21 PM   #8
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
I'd say it's normal. What's worth noting though is that with the new oil I just switched to, my engine is running 20 degrees F cooler than before. Used to avg around 240-250 regular driving and then 260+ hard. Now 220-230 regular and never crosses 250 degrees. OEM cooler setup.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      08-25-2014, 08:47 AM   #9
lowbudgethero
lowbudgethero's Avatar
125
Drives: '98 Z3M (gone), '09 135i
2009 BMW 135i  [8.50]
I'm about 230-240 in the hottest days of the year sitting in traffic or driving spiritedly. Last year when there were a number of 100+ days I would get up to 250 sitting in traffic. I have the OEM oil cooler.
      08-25-2014, 08:48 AM   #10
ejm3
200
Drives: 2012 135 Convertible 6MT
Around 250 is normal on my N55 when running at highway speeds. Care is bone stock.
2017 Acura MDX
      08-25-2014, 09:13 AM   #11
Ed P
29
Drives: 2016 Z4 Sdrive28i
What oil were you using, and what is the new oil?
I haven't changed the oil yet, but was planning on using Mobil-1 (probably 5w30).
Thanks!
2016 Z4 Sdrive 28i
Black Sapphire Metallic over Black Kansas Leather
... gone but never forgotten ...
2013 135i M-Sport
Mineral Gray over Oyster Boston Leather
      08-25-2014, 10:48 AM   #12
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Thanks!
Was using German Castrol. Switched recently to Motul 8100 5w-40
      08-27-2014, 11:53 AM   #13
Ed P
29
Hmm... OK so, most likely the previous oil was thinner, while the new oil handles hotter temps better.
I haven't checked the manual - anyone know what weight oil BMW recommends for the 135i (N55)?
Was planning on using 5w-30 (live in Florida).
Thanks!
2016 Z4 Sdrive 28i
2013 135i M-Sport
      08-27-2014, 01:42 PM   #14
Iron Man
Iron Man's Avatar
189
Drives: N/A
Thanks!
You can use 0W-30, 5W-30, 0W-40 or 5W-40. Make sure you use a LL-01 approved oil.
      08-27-2014, 01:46 PM   #15
Ed P
29
Thanks Iron Man!
I've been using 5w-30 Mobile-1 for years in my previous car (2006 MX-5). That's what I plan on using in the 135i... is it "LL-01 approved"?
2016 Z4 Sdrive 28i
2013 135i M-Sport
      08-27-2014, 02:00 PM   #16
Iron Man
Iron Man's Avatar
189
Drives: N/A
Thanks Iron Man!
No. Mobil 1 0W-40 is what you would want to use (if you want to stick with Mobil 1 products).
      08-27-2014, 02:44 PM   #17
Ed P
29
Thank you again -- I will be sure and specify that at my shop.
2016 Z4 Sdrive 28i
2013 135i M-Sport
      08-29-2014, 05:00 PM   #18
pick333
42
I read my temperature wrong--it is 240 degrees--about what everyone else is reporting.
      08-30-2014, 11:37 AM   #19
Downeaster1
BMW Master Tech
Downeaster1's Avatar
587
Drives: E30, E36, E82, E90, F10, F80
My oil constantly stays at 244F, and coolant is at 232F (+/- 3F for both).
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad
      08-30-2014, 02:00 PM   #20
..'s Avatar
62
Drives: 135i
http://www.burgertuning.com/sport_oil_cooler_valve.html
If you haven't already, I strong suggest you purchase this. One of the best mods you can do to your car for the least amount of money.
      08-30-2014, 08:14 PM   #21
Teqnik
That's pretty neat.
Do you have any feedback about this? Does it actually work?
      08-30-2014, 08:16 PM   #22
..'s Avatar
62
Drives: 135i
Originally Posted by Teqnik View Post
That's pretty neat.
I wouldn't be recommending it if it didn't!
Oil temps stay low! Even on the hottest of NY summer days in 90 degrees weather, my temps never see past 240.
1addicts
