08-23-2014, 04:02 PM | #1 |
32
Rep 203
Taking Steering Wheel off
Hello all, I recently purchased some aftermarket paddle shifters, and now I have to put them on. I watched the video by EAS on YouTube, but I can't seem to get the steering wheel off. I have a 2009 e92 coupe, so if anyone has any suggestions or knows anything that could help, please let me know. Thanks
08-23-2014, 08:23 PM | #2 |
Admiral
931
Rep 3,886
It's very simple. Make sure your battery is unplugged.
Take a flathead screwdriver and stick it horizontally into the holes on the back of the steering wheel, one by one. You should feel the airbag spring depress when you press into the wheel with the screwdriver. Pull the airbag off slightly on the first side, then when you move to the next side pull the airbag off completely. It will be attached by some wires. Once the airbag is off it's very straight forward
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
08-24-2014, 03:23 AM | #3 | |
32
Rep 203
08-24-2014, 06:33 AM | #4 | |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
screwdriver in there. No need to poke any extra holes. |
08-24-2014, 02:35 PM | #5 | ||
32
Rep 203
08-24-2014, 10:07 PM | #6 | |
20
Rep 816
08-25-2014, 05:54 AM | #7 | |
Currently Driving
269
Rep 1,426
08-25-2014, 05:55 AM | #8 |
Currently Driving
269
Rep 1,426
08-25-2014, 02:24 PM | #9 |
Bad Lieutenant
233
Rep 3,517
It's easier to remove the cover trim (with buttons and M badge) so you can see the spring you're supposed to compress.
You can remove the cover trim carefully by removing 3 torx screws behind the wheel and unplugging the buttons; extremely simple.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
08-25-2014, 02:59 PM | #10 |
Admiral
931
Rep 3,886
Idk why people are having so much difficulty with this. I swapped my whole steering wheel in about 15 minutes from start to finish a couple weeks ago. Just gently stick the flathead into the slit on the back of the steering wheel, and push it straight inwards. The spring is straight through the hole...
08-25-2014, 03:17 PM | #11 | |
32
Rep 203
08-25-2014, 03:18 PM | #12 | |
32
Rep 203
08-25-2014, 08:05 PM | #13 |
20
Rep 816
Your "indentations" or "holes" = his "slits". Yall are talking about the same thing.
