12-18-2007, 09:15 AM | #1 |
60
Rep 2,128
Z4MC footwell - smaller than the non-Ms?
I got into the Z4C this morning wearing my Timberland boots and immediately stepped on the gas and clutch together. Sure, I wear a size 15 shoe, but it was never an issue with my roadster. Is the transmission tunnel bigger on the Ms? Are the pedals more closely spaced?
12-18-2007, 09:33 AM | #2 |
My favorite sign.
169
Rep 4,333
I don't see how the footwells could be any different...
12-18-2007, 10:16 AM | #3 |
75
Rep 1,689
The transmission tunnel is bigger on the M models.
They use a different/larger tranny than the non M's. Beefier to handle the added horsepower although ESS proved the non M tranny will hold up just fine to the power levels. |
12-18-2007, 10:22 AM | #4 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Actually I think the pedals on my M Coupe are set up for perfect heel-toe shifting. Some might think it's too close, but for me I have never driven a car with a more perfect set-up even in its stock form.
If you pressed the accelerator and clutch at the same time, I am making the assumption you mashed the brake pedal too and you must have a HUGE foot!
You have to be 100% behind someone before you can stab them in the back.
David Brent |
12-18-2007, 10:41 AM | #5 |
11
Rep 212
I haven't measured, but it is definitely tight in that footwell. I don't think the size (length) of the shoe is the issue (I wear a 12 or 13), it's the width which causes a problem. I have never tried to wear boots in my MC, but when I wear dress shoes (Kenneth Cole) which tend to have a wide sole, I sometimes clip an unintended pedal here and there. I have gotten to the point where I actually have certain shoes which I wear when I drive the MC. This is not a problem since it's my second or "fun" car which I mainly use for weekends or errands.
12-18-2007, 11:02 AM | #6 | |
60
Rep 2,128
No big deal - I had a similar issue with my Porsches, but the other direction. The coupes had plenty of footroom, but the targa was tight due to the extra chassis reinforcement. |
12-18-2007, 12:53 PM | #7 | |
2434
Rep 11,668
I thought it was the same 6sp as the si, because of the narrow tunnel.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
12-18-2007, 01:01 PM | #8 |
75
Rep 1,689
12-18-2007, 01:21 PM | #9 |
2434
Rep 11,668
FWIW....Just checked RealOEM...
Both are listed as "GS6-37BZ/DZ" they do have different part #s, which I suspect is the different gearing
12-19-2007, 01:28 AM | #10 |
M Slut
18
Rep 564
Most true sport cars have pedals set up close together especially between the brake and accelerator pedal for ease in heel-toeing. I make a habit of placing my left foot on the dead pedal when it's not in use which helps in bracing my body during spirited driving. I drive every day like I'm on the track except for not driving at track speeds. It makes my technique become second nature when I actually hit the track. I may not look as cool as those who drive the one-handed gangsta lean method, but if I wanted to drive that sort of car, I would be on the Cadillac forum.
David Brent |
