07-26-2014, 02:44 PM | #1 |
collecting toys
41
Rep 810
FS: APEX ARC-8 18x10 ET 25 rims
Apex ARC-8 18x 10 ET 25 rims in satin black. Just what you need for tracking your e9x M3. Weight 19.9 lb, fits over big brake kits. BBK clearance: Many owners install Big Brake kits on their cars. Having an 18” wheel that can clear large calipers is a must. Due to the low offset nature of the E46 M3, there are no clearance issues with the concave spokes of the ARC-8 wheel. Barrel clearance was increased during the design phase to accommodate StopTech’s 380mm kit. The only kit that poses an issue at this time is the 380mm Brembo setup I have 2 of these babies left, so not a full set anymore. Good for replacement or if you have a set already and what to rotate additional tires on your car. The satin black is the color of brake dust so you don't even need to clean these They do have small scuffs on them, not through the paint, but these have been used. Absolutely no bent or dented parts, mechanically true. I tried to take pictures of the worst scuffs below. None can be seen beyond 4 ft from the rims. Since I only are a pair left and these don't have a centercap, $150 each ( you can either use your own center caps or get replacements from APEX at $9.95 each.) pressure sensors not included, just ignore the little red light Shipping cost not included. If you want perfect, you could powder coat these,
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold Last edited by arter; 07-30-2014 at 04:34 PM.. |
07-26-2014, 04:15 PM | #3 |
collecting toys
41
Rep 810
Only have 4 center caps so those rims are $160, the other two are $150
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
07-26-2014, 09:07 PM | #5 |
collecting toys
41
Rep 810
yes for the 4 with center caps. the other 2 $150
This is less than half price from new.
