TireRack
      07-21-2014, 07:02 PM   #1
HalP
2011 X5M Alpine White
HalP's Avatar
Drives: 2011 BMW X5M
2011 BMW X5M  [0.00]
E70 stainless brake line install warning
Hey everyone, I recently decided to install stainless steel brake lines on my 2011 Alpine White X5M. I had this done to my 2008 E70 X5 4.8i Sport back in 2010 by a local garage that is no longer in business, so I decided this time to do it myself. How hard could it be, right? I have done this on other vehicles I have owned over the years and it was always simple and straightforward.
For anyone considering doing this as a DIY, be VERY VERY CAREFUL not to let the the brake system completely bleed out during the swapping of the hoses! I accidentally made this mistake when I decided to paint my rear calipers during the swap. Even though I had the rear jacked up higher than usual, and raised the old hoses after removing the calipers, gravity wasn't my friend and when I returned to install the freshly painted calipers a few hours later, the overflow pan I had placed under the open hose was almost overflowing and my vehicle was brake fluid free!
I went ahead and swapped out the hoses and re-installed the rear calipers and attempted to bleed the system. That's when I ran into problems. I couldn't get all the air out of the system no matter how many times I bled the brakes (about a dozen attempts in all). Frustrated, I took it to my local BMW dealer and asked them to bleed them for me. IT TOOK THEM SIX HOURS to finally bleed the brakes and get all the air out! The tech was so frustrated he basically told me he was never going recommend swapping brake lines on an X to anyone from that point on! I'm pretty sure he was cussing me up and down by the end too (probably sooner than that)!
It ended up costing me over $600 in labor to get the brakes air free!
Just thought I would post this for anyone considering doing this. The stainless lines look great, perform great, and I'm glad they are now installed, but I don't think I would attempt this again. Something that used to be so simple, isn't simple any more! Which is true for just about anything on today's uber-sophisticated ultimate driving machines!
-Hal
2011 X5M Alpine White w/Bamboo Beige Perforated Full Merino Leather
      07-21-2014, 08:27 PM   #2
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
That is good to know. How does the brake pedal feel? Stainless lines a painted calipers i bet it looks nice.
      07-21-2014, 08:33 PM   #3
blue dragon
1192
Drives: '22 Tesla MY + '23 Tesla MY
This is not a stainless brake line issue. I'm running stainless braided lines with X5M caliperswith zero issues. The issue is that you failed to cap the open lines with the little rubber bung that comes with new lines, when you removed the caliper. Either way, glad you got it solved.
The dealer software will activate the ABS unit to remove bubbles that are stuck.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      07-21-2014, 09:09 PM   #4
HalP
HalP's Avatar
2011 BMW X5M  [0.00]
That is correct. Capping the lines will prevent this from happening. For some reason, the lines I bought didn't include any, but I probably could have mcgivered something.
The tech also told me he ran the ABS unit activation software six times before it finally cleared all the bubbles. Definitely adding to his frustration.
I have no issues with the brake lines at all, exactly as expected, firm pedal feel and look great.
-Hal
      07-21-2014, 09:37 PM   #5
mitch808
107
Drives: 2012 X5 35i
The trick/tools that a dealer has access to, to cycle the ABS system, is invaluable in cases like this. Otherwise, you'll end up doing what you ran into, with no promises to an end in sight.
Alternatively, you take it out for a drive, drive carefully, and find places to activate the ABS on your own (e.g. sandy/dirt area to do hard stops), then go home and bleed again, rinse repeat another time or two. (Ask me how I know this...)
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
      07-21-2014, 09:38 PM   #6
HalP
HalP's Avatar
2011 BMW X5M  [0.00]
BTW, I successfully upgraded the front brakes on my 2008 4.8i Sport to X5M rotors, calipers, shield and pads after reading your DIY. KUDO's and Thanks!
-Hal
      07-23-2014, 07:30 AM   #7
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
627
Drives: '11 E90 M3 & '13 F25 X3
I ran into this same problem on my previous 3 series. Luckily, I now have all the software used to code and troubleshoot, so when I did brakes on my current car, I ran the ABS activation at each wheel. The pedal was ROCK HARD.
Honestly, if you're flushing the system, even just for maintenance, its a good idea to do this to ensure you get all of the old fluid/air out of the system.
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      09-22-2017, 08:32 PM   #8
SilentAttack
SilentAttack's Avatar
163
Drives: 08 E90 Jerez Black 6MT
And I just took my calipars off to paint them. I planned on doing a full flush. Hopefully I don't run into issues
      09-22-2017, 11:49 PM   #9
msan
403
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
When doing anything requiring brake line disconnection you should use a stick and push the brake pedal down and use the driver seat and the stick to keep the pedal pressed down, you will lose little fluid if you do this. You can cap them for added insurance
      09-28-2017, 12:57 PM   #10
heatmizr
153
Drives: E70 X5 50i M-Sport
^ That sounds like an easy way to accidentally push the piston too far in your master cylinder and damage the seals on it. Be very careful... At least that can happen on a motorcycle master cylinder.
No need to do both, just cap the lines.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e70 X5 50i M-Sport "The Boss" Loaded
e90 328i - sold
e36 M3 - Gone to become a track star
      09-29-2017, 12:54 AM   #11
msan
403
It's straight from BMW TIS
      09-29-2017, 09:08 AM   #12
deansbimmer
Mporium BMW
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
That's not a thing. Holding the pedal down is common practice by those "in the know". It blocks flow from the reservoir, essentially shutting off the fluid flow.
      09-29-2017, 02:47 PM   #13
heatmizr
153
Huh, how about that... I have never seen the inside of the master cyl piston on an X5.
I know it can be an issue on bike brakes. Especially on older models where there could be corrosion inside the cylinder where the piston doesn't normally travel, and tear the rubber seals on the piston. Resulting in the need for a master cyl rebuild.
heatmizr [Todd]
e90 328i - sold
xbimmers
