06-29-2014, 08:39 PM | #1 |
23
Rep 177
How does timing work for open trackdays?
I usually participate in HPDE with an organization but plan on attending an open trackday.
What are timing options? Can I rent a transponder or will I need to buy one? Thanks, |
06-29-2014, 09:54 PM | #2 | |
853
Rep 1,681
06-30-2014, 09:35 AM | #3 |
594
Rep 4,488
You need to have all of the equipment in your own car, so either Harry's Lap Timer plus a smartphone (and other accessories if desired) or a standalone system like one of the TraqMate offerings. I don't know of any tracks that do the timing for you, probably because then people with insurance policies that remain in effect for non-timed, non-competitive events would have a harder time getting coverage for a claim even if they didn't use the transponder. And in any case, local datalogging gives you much more information that can help you improve your times, such as friction circles and GPS recordings showing different lines you took on different laps and your speeds in those segments so you can see which line is faster. And with an OBD accessory, you can also get RPMs, throttle and maybe brake position, etc.
All that said, I've been doing HPDEs for 3 years and even though I have the BMW Apps option and thus access to the awesome M Laptimer app, I've never used it. I can feel when I'm faster without needing a timer, I have the type of insurance policy mentioned above, and frankly timing yourself changes the decisions you make out on track, and not for the better -- which is undoubtedly why the few insurance policies that cover HPDEs are written the way they are. The Nurburgring police once said in an interview that 80% of the wrecks they salvage out there have a timing device running in them. At the end of the day, I'm out there to enjoy myself and I want to drive my car home intact more than I want an extra tenth of a second per lap. I haven't needed a timer to continue improving; I've found that checking my speedo at consistent points on track gives me a great sense of whether a new line I'm trying is better or worse if the difference isn't completely obvious. Asking an instructor to drive your car around the track can be very educational as well, not to mention staving off the "I would be so much faster with this mod" syndrome.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-30-2014, 09:46 AM | #4 |
11818
Rep 23,187
^^^may want to use tach reading not speedo as an idicator if you are improving speed.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
06-30-2014, 11:01 AM | #5 |
23
Rep 177
Ya laptimes can certainly affect the way one drives and how aggressive one is. When I tracked my motorcycle before, I never used a laptimer and I was able to keep up with the advanced group.
With that said, It would be nice to see if I am progressing though. Another way to do it is to run the timer but check it at the end of the day but this means I still need a timer in my car. |
06-30-2014, 11:10 AM | #6 | |
594
Rep 4,488
06-30-2014, 11:18 AM | #7 | |
594
Rep 4,488
But don't fool yourself into thinking that timing yourself and waiting to check later will sidestep the change in decision making. You'll still know you're turning in lap times somewhere. And in fact I would argue that that solution is the worst of both worlds because you have the risk of overaggressiveness AND lack of immediate feedback and the potential for improvement that that provides. Most people I see getting useful information from timing will review their data after each session because they went out that session knowing that on a certain lap number they would try a certain thing, so afterward they can match their various strategies to the respective resulting lap times. Usually they're also looking at telemetry though, not just times. In order to get useful information just out of times, you need to be able to drive extremely consistently so that you can be confident that some adjustment you made was responsible for the time difference you observed, as opposed to some other unintentional change elsewhere in the lap.
06-30-2014, 11:48 AM | #8 |
81
Rep 1,510
1. Rent a transponder from your club (not track), if offered. Lap time only
2. Buy an app on your phone (Harry's Laptimer/Trackmaster) with optional GPS transceiver. Lap time and rudimentary data analysis 3. Buy a dedicated track timing solution (traqmate/Aim etc) to really find out how to improve. Suffice to say that you need to check with the clubs you run with, whether they allow any of these solutions in your specific run groups |
06-30-2014, 12:01 PM | #9 | |
11818
Rep 23,187
06-30-2014, 03:36 PM | #10 | |
23
Rep 177
Thanks, even with timing and I usually pretty consistent when I do a 5-6 lap session. I am mostly within seconds of each laptime given that all parts and tires are working. Not referring to when tire slips and gets greasy, then that session is done.
06-30-2014, 03:47 PM | #11 |
594
Rep 4,488
If your lap times are seconds (plural) apart, that's not considered very consistent. Barring issues on the track like running into traffic, your lap times should vary by no more than a few tenths if you want to use just lap time data to determine whether your adjustments are for the better or worse, otherwise the natural variability in your lap times will make it impossible to determine the true effect of the change you're experimenting with. But if you just want to make sure your times continue to drop (without trying to figure out why they're dropping or how to make them drop further), then I suppose variability doesn't matter as long as the trend is downward.
07-01-2014, 04:15 PM | #13 |
23
Rep 177
07-01-2014, 04:20 PM | #14 |
28
Rep 300
external gps receiver allows more frequent updates.. 5 to 10 hz versus 1 hz with internal receivers.
07-01-2014, 04:32 PM | #15 | |
594
Rep 4,488
But of course the iPhone has GPS too, so an external receiver isn't required; it's just higher resolution as the person above me said.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 07-01-2014 at 04:41 PM.. |
07-01-2014, 04:34 PM | #16 | |
23
Rep 177
07-01-2014, 04:42 PM | #17 | |
594
Rep 4,488
07-01-2014, 04:59 PM | #18 | |
28
Rep 300
Check out RaceChrono.....Of the 3 different timing apps that I use, RaceChrono is IMO the easiest to use. The Pro Version does everything that Harry'sLT does with a simpler interface. It supports a BlueTooth GPS interface. |
07-01-2014, 08:34 PM | #19 | |
23
Rep 177
