06-29-2014, 05:17 AM | #1 |
58
Rep 554
Drives: 08 M3 Space Gray/MT
Running 265/35/18 tires on Apex Arc8 18x10et25??
I have new set of Hankook 265/35/18 RS3 that I was going to run on a 18x9.5 wheel for the occasional track/mostly daily but now I want a set of Apex Arc8 18x10 et 25. I know it will fit but will it be safe for the track (Willow Springs). I know most run 275 but seeing if 265 could work so I can burn through this set before I order new rubber.
RPI GTc/ RPI X-Pipe/DINAN Stage2/KWV3/18" BC Forged RS41/Mode Carbon V2 GTS/RPI AF + Red Scoops/Lux Angel Eyes.
06-29-2014, 07:39 AM | #2 |
collecting toys
41
Rep 810
mfg recommendation rim size for 265/35/18 is 9.0 to 10.5 inches, so your 10 inches rims should be okay
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
06-29-2014, 05:13 PM | #4 |
58
Rep 554
Great, thanks guys.
06-29-2014, 07:00 PM | #5 |
2745
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
You should expect to need spacers in the front.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
06-30-2014, 11:16 AM | #7 |
367
Rep 1,036
18x10" ET25 rims have a known issue with KW coilovers (V3 and clubsports) and inner barrel clearance. I believe a 5mm spacer should be sufficient for clearance with this setup.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
07-01-2014, 01:14 PM | #9 | |
BimmerPost Supporting Vendor
3555
Rep 6,798
TC Klines should be utilizing a linear race spring on their coilover system, so there should not be any issues with the 18x10" ET25 fitment.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
