06-25-2014, 11:13 PM | #1 |
Rep 47
Another Price Drop!! Get these outa my garage . 2 x 255/35/19 2 x 275/35/19 ~3k miles on these. 6/32 & 7/32 on 255s 4/32 on 275s slight track rash on the outer shoulders of the 255s but they can be mounted either L or R One W-rated plug in on of the 275s Asking $250. Will ship. Last edited by CM3LLO; 07-09-2014 at 06:58 PM.. Reason: Price Drop!! |
06-26-2014, 03:54 PM | #8 |
184
Rep 3,939
I am also interested. How do these fit the OEM 220's? Do they throw off the speedo given that the aspect ratio is the same but they are wider?
07-06-2014, 06:52 PM | #9 |
Rep 47
Sorry, I just realized I never replied to you on this…
The front tires are 4% wider than stock which means the diameter is also 4% larger which means the circumference is 4% larger. In the end this equates to a 4% speed increase vs. what the speedo reads. So at 55mph on the speedo, your actual speed would be 57.2mph. I think |
07-10-2014, 12:35 AM | #13 | |
569
Rep 3,742
You are correct that the width (255 mm) is 4% wider than stock (245 mm), but since the aspect ratio is only 35, that means that only 35% of the increased width translates to increased sidewall height. In reality, the difference in diameters between 245/35/19 and 255/35/19 is just over 1%, which is very negligible. (A delta of 3% or more is not recommended.) |
