06-25-2014, 05:29 PM | #1 |
27
Rep 472
0.3 psi?????
Just installed a pre owned p3 gauge and finally got it to work(kinda). At idle or stop, gauge is reading between -17 to -22. However at full wot, it's only boosting to 0.3 max. Only weird symptom is a slight whistle(sounds almost like a creak) as I start moving. Could a leak cause normal vacuum reading but low boost? I have a stage 2 AA kit that should show peak 8 psi(give or take)
06-27-2014, 06:23 AM | #2 |
12
Rep 71
Sounds like you have a vac/boost leak somewhere. I had the same issue when I installed the same gauge with my ESS kit. Make sure you zip tied every connection point. That solved my problem and you will def feel the difference. Hope that helps. Good luck
BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger with 5lb pully and tune . Akrapovic GT4 Exhaust Full system . Arkym rear diffuser 1+1 . BMW performance cf trunk spoiler with CRT red stripe . Alpine coding . ZCP illuminated shift knob(DIY) . Exterior LED lights .
06-27-2014, 08:44 AM | #3 |
27
Rep 472
Would it read vacuum to -20 if there was a leak though? Generally a leak would keep pressure closer to 0(equilibrium) right? Unless it's a one way leak.... I'll double check connections to be sure.
06-27-2014, 10:50 AM | #4 |
21
Rep 313
Does the car make power? If you actually only have boost of 0.3 psi, then you should immediately notice it. If the car makes normal "boosted" power, then your gauge is broken.
06-27-2014, 11:08 AM | #5 |
27
Rep 472
It's definitely more power than stock but i don't really know how a properly boosted M3 is supposed to feel on the kit that I have. I'm gonna try blowing into it and seeing if it measures more than 0.3 psi.
06-27-2014, 04:38 PM | #6 |
1469
Rep 3,157
06-27-2014, 04:50 PM | #7 |
27
Rep 472
06-27-2014, 05:38 PM | #8 |
27
Rep 472
Slight update: I disconnected the vacuum hose from gauge control box and blew directly into the control box sensor and it's registering at most 2 psi no matter how hard I blow into it. So the sensor is bad?
06-28-2014, 12:50 PM | #9 |
12
Rep 71
Yes it would still read the vac. If you blow into the tube and the gauge reading changes, the gauge should be working. I noticed that you didn't zip tie the connection where it was t'd off the bov. When you start hitting higher boost, it seems to leak from those points, at least for me, that was the issue. I simply went back and zip tied EVERY connection point, including where the tube connects to the box under your dash. That fixed the problem. That would be my suggestion as it sounds like the exact symptoms I had.
