TireRack
      06-21-2014, 09:53 AM   #1
094.8x5
Drives: black on black on black
Brake job
My son and i have done all our cars/trucks in the past. Never done an X5,,,any tips tricks or cautions ? any special tools needed ? computer re-sets ? any recommended pads ? Thanks much
      06-21-2014, 11:00 AM   #2
mitch808
107
Drives: 2012 X5 35i
I know there are videos on youtube. There is also a great looking impact screwdriver sold by a vendor on here for the purpose of rotors, among other things. It's not a specialty tool, just a nice to have.
As for parts. Centric makes excellent rotors of OE quality. If they make it, go for the Centric Premium units with painted hubs. Raybestos "Advanced Technology," has a similar rotor with painted hat.
As for pads and sensors, centric has those. you can also get parts from Hawk, and Stoptech. A standard ceramic pad is fine in 80%+ of cases. Towing? opt for a semi-metallic pad.
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
      06-21-2014, 07:46 PM   #3
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
No special tools, just replace brake sensor if needed. One on the left front caliper and one on the right rear caliper. Just Remove anti rattle clips and remove the two black plug covers behind the caliper and insert the No 7 hex socket. If removing the rotors, you will have 2 bolts holding on the caliper bracket and then there is 1 hex screw holding on the rotor. Hopefully it not rusted on. You know the rest, Very easy.
      06-24-2014, 11:04 AM   #4
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
This is the one special tool you'll need depending on the brakes. My 50i M Sport does not use a 7mm hex bolt, as most/all other BMWs seem to. It's 10mm, and that size is nearly impossible to find.
I have a thread on here about painting my calipers which I did this Spring, I go into more details there.
Otherwise, yup, super easy.
      01-06-2015, 11:12 AM   #5
Z@T
Pilot
Z@T's Avatar
19
Drives: M3, Vantage, 997, ModelX
I'm digging out this thread since I have to do a brake job on my X5d soon. (4k miles left on BC and BMW quoted me a replacement when I had the DEF refilled)
The dust with the OEM pads is IMO ridiculous.
Any recommendations on low dust brake pads?
Has anyone experience with the low dust pads?
http://www.ecstuning.com/ES2167890/
      01-06-2015, 11:36 AM   #6
mitch808
107
Drives: 2012 X5 35i
HarborFreight. Not impossible, and very inexpensive for a set of metric sized socket hex bits. That's where I got mine for my Aprilia bike and a few other aftermarket suspension items related to my Subaru
      01-08-2015, 11:47 AM   #7
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I have an 08, 3.0si. I have replaced both front and back. I used Brembo rotors and Akebono pads. NO dust what so ever. The only thing with Akebono is that the pads NEED to be burnished to the new rotors and they pads will take about 1000 miles before you really get the 100% power of braking back. Once you get past the 1000 mile mark, they feel like OEM brakes in my opinion.
You should get a brake vac and change out the brake fluid while you are in there. You will need a Mitivac or some other similar type of tool you can hook up to an air compressor. There are plenty of DIY videos on how to do this. I use Amsoil DOT 4 brake fluid.
Cost is probably :
$40.00 brake fluid
Mitivac - $130.00
Akebono Pads Front & Back - $130.00
Brembo Rotors Front & Back - $275.00
New retaining clips - $30 to 40.00
New Sensors front and back $40 to 50.00
      01-12-2015, 11:46 AM   #8
Z@T
Pilot
Z@T's Avatar
19
Cost is probably :
$40.00 brake fluid
Mitivac - $130.00
Thank you! That is the info I was looking for..
The front brakes were recently done with warranty!
I'll go the same route for my rears.
      01-13-2015, 07:15 AM   #9
Cattivo
FDNY Engine 55
Cattivo's Avatar
681
Drives: X5M, X5 50i Msport, EscaHoe
I just recently replaced my rear brake pads and now I have the brake light on my dash... do I need to go to the stealership to get it removed or is there a way to reset it?
      01-13-2015, 08:18 AM   #10
WallyM5
WallyM5's Avatar
42
Drives: X5M, R63 AMG, F-450
Did you reset your service indicator in the iDrive? If not you can do that your self. Also did you replace the brake wear sensor? If not you will need to because they are a measured sensor and will only last a certain period of time.
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete
OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer
      01-13-2015, 08:45 AM   #11
Cattivo
FDNY Engine 55
Cattivo's Avatar
681
I wasn't aware that I could reset service indicator in the iDrive ...yes I replaced the break wear sensors so ill try to reset the service indicator in the iDrive...thanks
xbimmers
